6 speed gear recommended
Feb 21, 2007 | 11:12 AM
What gear is best to drive around town at 45-50
Feb 21, 2007 | 11:13 AM
1st. Maybe 2nd, but I wouldn't go any higher than that. Try 1st and let us know how it works.
Feb 21, 2007 | 11:15 AM
are you serious--50 mph in first or second around town
Quote:
Originally Posted by
YELLOHHH
See I have the DTE Stage 1 diff w/ 4.10:1 gear ratio. 1st doesn't go up that high, so I use 2nd to cruise at 45-50. Really keeps it in the power band.
Dan
Feb 21, 2007 | 11:18 AM
my 99 is stock----what rpm's should i stay around in town--not to worried about gas mileage
Feb 21, 2007 | 11:26 AM
dthompson
What gear is best to drive around town at 45-50. my 99 is stock----what rpm's should i stay around in town
Some of the stuff that gets asked on this Forum these days is simply
Feb 21, 2007 | 11:30 AM
To be serious: Around 2000, +/- 250.
Feb 21, 2007 | 11:36 AM
St. Jude Donor '06
Take it easy on the noob you guys.
like mentioned above. around 2000, if you want to save gas, then keep it in 6th.
Feb 21, 2007 | 11:38 AM
VinnyT
lol Yeah - man, if you have the manual, read it. Theres a LOT of good info in your manual about your C5. including it's recommended shift points.
I believe it says for 'best gas mileage' (basically just putting around town) it should be like this:
2nd @ 15
3rd @ 25
4th @ 35
5th @ 45
6th @ 55
But the reality is you can skip gears easily - hell it's even built in w/ CAGS between 15-20mph. The idea is to mope around at ~1600-2000RPMs like VinnyT said.
So at 45-50 I'd be in 5th gear ~ 1600RPMs (assuming 3.42 rear end) and call it good.
Dan
Feb 21, 2007 | 11:39 AM
VinnyT
Feb 21, 2007 | 11:42 AM
Turn down the stereo and listen to the engine. It'll tell you if the gear is too high. If it sounds like it's laboring, downshift.
Feb 21, 2007 | 11:49 AM
dthompson
Yes, and if you drop under 25 mph, put it in reverse and drive backwards. This will save wear and tear on the forward gears.
Feb 21, 2007 | 01:19 PM
YELLOHHH
Stop!! My ribs hurt.
Feb 21, 2007 | 01:41 PM
Cajun99
...if you have to ask, maybe you should get an auto.
Feb 21, 2007 | 02:10 PM
yea it seems to me like it amuses a lot of people on this forum when a "noob" asks a "dumb" question, but what everyone seems to forget is that at one point or another, everyones been in that situation.
Feb 21, 2007 | 02:16 PM
Feb 21, 2007 | 02:17 PM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
3rd/4th.....
Feb 21, 2007 | 02:20 PM
easy guys....
at 45 50 i stay in 4th or 5th. 6th is better for gas but i like to goose her a little now and then and have the power there
Feb 21, 2007 | 02:35 PM
Between 40 - 45 mph, I'm in 6th.
Feb 21, 2007 | 02:48 PM
casisthefirst
Negative.
