Overheating problems 2 times in 1 month..
Thanks!
C5's are like a Hoover vacuum - they suck up a LOT of leaves, grass, plastic bags, etc. etc. etc from the road - and much of that debris ends up in the radiator area as described above.
There is a cure for this (other than not driving) - many Forum vendors sell a debris guard that takes about 10 minutes to install - and it works.
P.S. When you say hot, how hot? In traffic, or on the highway?
Well its in the shop right now waiting to get looked at tomorrow..so I'll post what happened..hopefully its only what you say it was..but I don't know anything about cars so this was really helpful..
Thanks again!
how hot with the factory settings 225-230 not uncommon in traffic!
normalYou can make sure no air is in the cooling system by following the steps in this link starting at step 11.
http://forums.corvetteforum.com/show...ain&forum_id=1
Thanks for the help!!
Assuming the thermostat is good since it was just replaced then the coolant level may be insufficient. Other worse things could be possible.
Here are some possibilities:
Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) #00-06-02-001 - (Jan 5, 2000)
Engine Running Hot, Overheating and/or Loss of Coolant (Polish Radiator Filler Neck and Replace Radiator Cap)
1999-2000 Passenger Cars and Trucks with Composite Radiator End Tank
Condition
Some customers may comment on one or more of the following conditions:
Engine running hot
Engine overheating, and/or
Loss of coolant/low coolant message
Cause
The radiator filler neck may have an imperfection in the sealing surface.
Correction
Important
DO NOT REPLACE THE RADIATOR.
Using a piece of 400 grit wet/dry sandpaper backed with a flat piece of wood, polish the filler neck sealing surface using a circular motion.
Replace the radiator pressure cap with a cap of the same part number as shown in the GM Service Parts Catalog.
Diagnostic Procedure for Overheating Condition
Engine Overheating
Step
Action
Yes
No
1
Inspect for a missing or damaged radiator upper or lower baffle and/or radiator air deflector.
Is the baffle and/or deflector missing or damaged?
Go to Step 8
Go to Step 2
2
Inspect for a loss of coolant.
Is there a loss of coolant?
Go to Step 3
Go to Step 4
3
Fill the system to the specified level. Refer to Loss of Coolant .
Does the engine overheat?
Go to Step 4
System OK
4
Inspect for low coolant protection.
Is the coolant to the correct concentration?
Go to Step 5
Go to Step 8
5
Inspect for a loss of cooling system pressure.
Is there a loss of system pressure?
Go to Step 8
Go to Step 6
6
Inspect for a faulty engine coolant temperature (ECT) sensor. Refer to DTC P0117 , DTC P0118 , or DTC P0125 in Engine Controls - 5.7L.
Is the sensor operating properly?
Go to Step 7
Go to Step 8
7
Inspect for a cracked coolant surge tank or a leaking hose.
Is the coolant surge tank cracked or is the hose leaking?
Go to Step 8
Go to Step 13
8
Repair or install new parts as necessary, then retest.
Go to Step 9
System OK
9
Inspect for incorrect drive belt tension.
Is the belt tension correct?
Go to Step 10
Go to Step 8
10
Remove the water pump. Refer to Water Pump Replacement .
Inspect for a damaged water pump driveshaft.
Is the water pump driveshaft damaged or is the seal leaking?
Go to Step 8
Go to Step 11
11
Inspect for obstructed radiator air flow or bent radiator fins.
Is the radiator air flow obstructed?
Go to Step 8
Go to Step 12
12
Inspect for blocked cooling system passages.
Are the cooling system passages blocked?
Go to Step 8
Go to Step 13
13
Inspect for inoperative cooling fans. Refer to Cooling Fan Inoperative .
Are the cooling fans and the motors operating correctly?
Go to Step 14
Go to Step 8
14
Inspect the thermostat. Refer to Thermostat Diagnosis .
Is the thermostat stuck in the closed position?
Go to Step 15
Go to Step 16
15
Replace the thermostat. Refer to Thermostat Replacement .
Go to Step 16
System OK
16
Inspect the radiator cooling capacity.
Is the proper sized radiator being used on the vehicle?
Go to Step 3
Go to Step 17
17
Consult the current parts catalog and replace the radiator. Refer to Radiator Replacement .
Is the repair complete?
System OK
Bill
Thanks Everyone for the help..now I know somethings to look for just in case it happens again..
Glad your prob didn't hurt at all Matty K.
Mick
