I wish I had a cable, I can tell a slight delay in the throttle response in a cable and servo, and even between servos. My truck is fly by wire as well and it doesnt have as much of a delay.
From: It is a tale told by an idiot, full of sound and fury, signifying nothing. Alto MI
I'm not worried about it failing tho
P
I'm not sure how you can feel the difference, but, like most things on the C5, couldn't you have it electronically adjusted?
I've got the cable in my 04 GTO. I hate it when the pedal pushes back at you when the traction control kicks in. I like the drive by wire in the Vette much better.
Hey, do you want Mr. Goodwrench to begin looking like Mr. Maytag. If you do convince GM to make your recommended change, see if you can them them to do the following:
1. eliminate inherent alternator problems between 1982 and 1997.
2. eliminate rear brake problems on 90+ GM models.
3. eliminate window problems on most GMs in past 10 years.
4. eliminate a/c problems (doors under right side of dash on late model cadillac.
5. eliminate major oil leak problems on northstar between 93 and 99.
6. eliminate stripped head bolts on northstar between 93 and 99.
I'm not sure if I know what the big advantage is for this and if it justifies the extra cost to build.
Anyone know?
Tunning for one but the bigest is AH and TC. When the PCM gets wheel spin with TC on, it backs off the throttle in regards to wheel spin. So you could just keep it to the wood and the car will get just enough to hook. Just my .02$
I only had one issue with a servo, but that was on an LS2 TB, and a very early harness. We had to de-engineer it to get it to work Off topic but the LS2 TB fealt very stiff and spungy off idle. I went that way to get my wife to drive the car more, but I hated it, and went to a NW 90mm TB... Thanks!
Dave
You might have a really neat idea.
Ed
I'm assuming you had a Cadillac? I had a 98 Deville and always worried about the head gaskets failing. I did the coolant change just to be sure. Here is one more:
The throttle is just but another one of the many items that goes into the PCM that controls engine performance. There are certain conditions (don't know exactly all the things) that WOT at the foot, may not translate to WOT at the engine due to air temps, spark advance, Outside air temp/ Fuel air mix as detected by O2 sensors, etc, etc.
Actually, the first drive by wire I had was in a Cadillac - Eldorado ETC,300HP Northstar.
When I got the car, I knew it had the best throttle response I had ever driven. Later, I found out it was drive by wire.
My current DD, Acura RL, also has it. Now the 'vette. I think it is much superior to cable. No pressure variation, perfectly linear. I have no interest in going back to cable or do have any fear of it failing.
I just sold my 97 pearl crimson (candy apple red) Sedan de Ville. 27k miles on it. Most beautiful car in country. I never had any problems with mine, but I know quite a few caddy mechanics. I will miss that car, but it is now 10 years old. Couple that bought it did not even take it for a test drive. That is the second time that I have sold a car without a test drive.
I still like GM products, considering the fact that Ford trannies go out at 100k. Also, you have to take the entire front cap off of a Taurus to get at a/c and/or radiator.
Best kept secret in America is the Buick. Centuries are great for kids. LeSabres and Centuries get 200k miles as long as you maintain them.
Ed
Ed
