Need Help... Water Leak
Old Feb 23, 2007 | 02:37 PM
98C5for2's Avatar
98C5for2
Default Need Help... Water Leak
I'm sure that a similar question/answer has been posted, so if anyone can direct me to that post, or if anyone has new ideas, I need your help.
I have a '03 Z06 that's been in 2 rainstorms. Both times the was water coming in from under the dash. After the first rain, I had the windshield replaced with new rubber, and was assured that everything would be OK!! But yesterday in a medium California rainstorm, more leaking. Any ideas on where to start looking. Thanks
Old Feb 23, 2007 | 02:41 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Udders? - http://forums.corvetteforum.com/show...ghlight=udders
Old Feb 23, 2007 | 03:46 PM
98C5for2's Avatar
98C5for2
Originally Posted by ptdrummer54
OK, I checked the udders, they appear to be clean. Next step?
Old Feb 23, 2007 | 03:57 PM
kenzo's Avatar
kenzo
Is the water coming down by the clutch? If so the drain is probably clogged. This happened to me and the water built up and followed the hood release cable under the dash. I had to remove the wipers and cowl. compressed air cleaned out the debris. No problem after the cleaning.
Old Feb 23, 2007 | 04:53 PM
98C5for2's Avatar
98C5for2
The first time it was coming from the clutch area also pass. side near A pillar. Yesterday, it was just the pass side
To Need Help... Water Leak
