Level surface in my garage. To clarify, the car is lowered on stock bolts. Is your car lowered to the max on stock bolts? If so, I would really appreciate if you could take measurements(ground to top of fenderwell) of all four corners on a flat surface. Thanks...
My car is all screwed up right now. I tried setting the ride heights of my car in my driveway/garage. For me to get it level, I had to completely remove the front right bolt and lift the front left for it to sit level. I've since gone back to both bolts installed up front and backed out all the way to get it as low as possible. It still isn't nearly as low as a lot of cars I've seen with cut bushings... I've got front and rear bushings cut. I've been trying to find a place around here that will get my ride heights set perfectly, but have been unsuccessful.
If I were you, I'd check very closely how level your garage is.
I checked the surface using one of those things that measure how flat a surface is, my garage is flat. I think I'm going to cut the top portion of the bushing on the drivers side, then all four corners should measure out evenly.
