I know folks with moderate H/C setups (420-440rwhp) that don't do a lot of drag racing, but drive the car hard around town and do a few (4-5) DE's a year and have done well with the stock setup.
From what I've read, the LS7 clutch is the next best thing to a stock setup in terms of drivability and sounds like it adds a little "insurance" at that ~440-ish HP levels, and holds pretty well up to ~475 or so.
With a clutch (and especially if you're running LT's which adds a extra PITA factor to a clutch swap) I'd build in a good 75+ HP buffer so I wouldn't have to worry as much.
So if I was putting together a targeted 450rwhp buildup, I'd go ahead and budget in a clutch that would hold 500-525, so I could grow my setup, add a little shot, etc.
Nothing is worse than underbuying a clutch!
I'm thinking about a OZ700 for my next setup - that will allow me to grow from a 375HP car upwards to a 700HP and maintain a decent amount of "streetability" - the only downside is a little firmer pedal and about 3X the cost of a stock setup (but think of all the time/$$$ if you have to replace a stocker premature!)
Well I have a stock LS6 clutch and in a few weeks getting the Vararam, American racing headers, and custom ECS cam and with that set-up alot of people make from 430-445rwhp. Just wondering if I'll be ok for awhile till I can afforde a new clucth and maybe some trickflow heads. Thanks for the well thought out reply!!
Nice sounds like it's going to be a killer setup! The TFS heads have been generating some great numbers too.
I think a big factor in how a clutch survives is how it's used - I had a Supra with BIG numbers, and managed to blow out a couple of dual plate setups doing serious slip and high RPM dumps on a strip. (These were $1000+ setups). Later I switched to an RPS disk and used the OEM pressure plate and that lasted for like 2 years with the same HP levels (and even a couple of road track events).
Sounds like your plans will take you to a point where you should start considering one of the beefier aftermarket setups (like the OZ700 I mentioned). As I plan my setup I'm spending alot of attention on the clutch and supporting driveline mods (like a DTE brake, possible a slightly built rear, likely at least 300M shafts).
Good luck!
DT
Thanks DT!! Yea man I love Supras also. Yea I guess I'll take it pretty easy on this set-up and when I save up some more cash I'll get a better clucth from ECS when they install the trickflow heads. Thanks man
Right now I am at 486hp/503tq on the juice. The LS6 clutch is holding but the hydralics are not. After a run on the juice the peddle will go away and have to be pumped a few times. I do not get any clutch slipage just a mushy peddle. Off the spray I have no problems at all 383hp.
I have the ls7 and so far so good at 430rwhp. I don't drag, but I have launched at 5k and it gets a little soft, back it down to 3k-3.5k and it seems to hold fine. It also holds on the road course shifting almost at rev limit, downshifting/heel toe, no problems last season. I blew an rps clutch with less hp(383) after about 10k hard street miles, and about 400-500 road course miles, seems like it just didn't want to be slipped at street lights.
When you are looking at buying a clutch it's the flywheel torque you have to keep in mind. The torque is what will give you a more accurate estimate of what clutch you will need. I have a Spec Stage II and using my 425 rwtq I estimate that I have about 490 ft-lbs at the flywheel. If I remember correctly the clutch is rated for 525 ft-lbs. I only have about a 35 ft-lb buffer but I have never had the clutch slip. When my car was put on the dyno after my H/C setup my stock clutch slipped badly. I ended up leaving my car with Vengeance and they had to tear the car back apart to install the Spec clutch.
If you are going to have the motor out I would not leave the LS6 clutch in and take a chance because if it slips you will be pissed that you have to take the car back apart.
Driving habits set the threshold for a clutch. Driven hard and subjected to launches without a lot of intentional slip, the LS6 clutch will hold 380-390 without issue. That assumes good following of the clutch fluid swap protocol.
If an owner doesn't launch the car or hammer high-rpm shifts, an LS6 clutch will support 450 rwhp or so.
But the LS7 clutch...oh my.
It will break your heart, if you drive the car like you did a bone-stock C5Z06. It will glaze on a launch above 3600 and will simply not accept a launch with 10 feet of slip even at a measely 3000 rpm.
So I'd suggest anyone that intends to launch a Corvette to stay far away from the LS7 clutch.
Ranger
Ranger think thats becuase of the power difference in the car or the clutch (material) itself?
LUK makes the clutches for the LS-motor Corvettes. The LS7 clutch lacks the proportionate stoutness (a combination of clamping power at rest and under centrifugal load) needed for a 450 rwhp motor.
That doesn't become an issue unless the car is launched or subjected to high rpm shifts. But an LS6 clutch would take it in a C5Z at stock horsepower. And because of that, it is a logical expectation that the LS7 would be stronger and better and would take it too in a stock C6Z.
Unfortunately, the logic fails in reality. The LS7 clutch lacks the stoutness one expects. So an owner of one must adjust launch procedures to the limitation of the LS7 clutch. That mean accepting that the car will bog, because the launch rpm cannot be raised appropriately without glazing the clutch. That is at stock C6Z rwhp level of about 450.
just bought a 2001 zo6 with a procharger and some other mods and its making over 550 rwhp on stock clutch. like i said i just got and havent got on it to bad yet, and i guess i better not either. any ideas on a good clutch setup and how much they cost installed, my car also has long tubes on it. ty
My advice is to get on an aggressive program of getting and keeping the clutch fluid clean.
And then, when the current clutch is worn out, look seriously at the Cartek clutch or the textralia brand. You'll need to choose the model based on your particular driving style.
Everything the car does, depends on the clutch. So it's not an area to skimp. Also choose your installer with special care. Too many reports of botched installs leading to vibrations.
Ranger
Ranger -
I've read the balance or don't balance a flywheel threads here before.
What were you referring to you talk about a "botched" install causing a vibration? Some clutch and flywheel packages come balanced together. With the exception of that, what could cause vibration when doing an install?
From you LS6 days, did you ever change the flywheel and not change out the rest of the clutch? Do you zero balance flywheels?
I have 442rwhp, 410rwtq on a stock Z06 clutch with 6,676 miles on it. As Ranger stated, if you don't launch insane or powershift/bang shifts all the time it WILL hold up. I was very surprised and pleased that my stock LS6 clutch lasted all last season (though it is on it's way out the door...I still don't feel it slipping but I know it's coming!). I went to the track about 3 times last year and cruise/drive hard about once or twice a week during the spring/summer. It shoud last for a bit then!
thanks,
mike
I advocate zero balancing a new clutch before it's installed. I've only had LUK clutches and every one was out of balance before they were sent to a machine shop for proper balancing.
Also if the clutch needs replacing, it is worth replacing all the component parts, not just most of them. That includes the hydraulics.
Finally, find an installer who's done a lot of C5/C6 clutches and has a good reputation. The install is only good if the tech is meticulous.
^ Actually you should match your new clutch to the old one comming out. Many times GM purposly installs an off-balanced clutch assembly to make up for any off-balance motors at final testing.
Early service manuals specifically state to swap all flywheel balance weights, later ones do not. C4C5specialist of www.corvettemechanic.com says to transfer on all installs. However most aftermarket assemblies do not have the provisions (holes) in the back of the flywheel in which to transfer the weights.
Take your new equipment and the old to a machine shop to have them match balanced... this is the only way to verify you will not have a new vibration when changing clutches.
Early service manuals specifically state to swap all flywheel balance weights, later ones do not. C4C5specialist of www.corvettemechanic.com says to transfer on all installs. However most aftermarket assemblies do not have to provisions (holes) in the back of the flywheel in which to transfer the weights.
Ask me how I know.
My 01 Z06 had balance pins in the original flywheel.
My 02 did not.
The GM procedure that dealer techs follow changed in 2003.
What Cobra is poining out is why I never change a clutch unless necessary and I carefully maintain my clutch fluid.
