4 Post Lift
Old Feb 25, 2007 | 11:55 AM
bkemp's Avatar
bkemp
Default 4 Post Lift
I'm thinking about installing a 4 post lift and have it narrowed down to the Superlift, Bendpak or Backyard Buddy. What I'm looking for is stability, I don't want something that wobbles while working under it. Are the lifts with the inside slides as stable as the ones with the outside slides, like the Backyard Buddy. I would like to hear your input!
Bill
Old Feb 25, 2007 | 11:58 AM
oaks99's Avatar
oaks99
bill
i've got direct lift 9000 lb it is great , VAROOM2 has the superlift 7000 lb and has had 0 problems with it . you can pm him or i'm sure he will respond sometime . good luck if you have more ? just pm me .
oak
Old Feb 25, 2007 | 12:07 PM
hotwheels57's Avatar
hotwheels57
I've had a SUPERLIFT 7000# four post in the past and currently have a BEND PACK HD9 four post lift...both professionally installed by manufacturer recommended installers. Both are very stable w/o bolt securing to the floor. I would recommend either manufacturer.
The BEND PACK has a secondary air locking system that requires an air compressor, which most shops have anyway. It's more "commercial" grade than most "hobby" storage lifts.
Always keep in mind safety and weight limitations, users knowledge and floor grade. My shops have all had 0 grade, absolutely flat. I also don't allow anyone to use my lift to avoid home insurance issues.
I don't care for the BACKYARD BUDDY personally.
Novat_99's Avatar
Novat_99
Bill,
I've got a Rotary Revolution 4 post lift....it's extremely well made & stable (it's got the inside sliders)...you might also want to check it out.
Tom
Old Feb 25, 2007 | 12:16 PM
bkemp's Avatar
bkemp
Originally Posted by Novat_99
Bill,
Tom
Tom, where did you get your lift
Old Feb 25, 2007 | 12:31 PM
Novat_99's Avatar
Novat_99
Bill,
I purchased the lift last August at Carlisle from Danny at Kwiklift...see here:
http://www.kwiklift.com/FourPostLift/index.htm
Here's the Rotary Revolution site:
http://www.revolutionlifts.com/
The lift meets a number of independent safety standards....see here:
http://www.revolutionlifts.com/liftStandards.asp
If you have any other questions...just let me know.
Tom
Old Feb 25, 2007 | 01:07 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Bill
I have a Superlift SJ7000 strictly for home use. My neighbor has one too. Nice unit for the price. Watch for the specials they run from time to time. Get the AL ramps, the steel units are 50# each and a PITA to deal with. Any of the lifts with cams that rest on blocks can be moved side to side when the car is elevated at 50% or more of the max. lift height. However, for storage or most bottom side maintenance this isn't going to be a problem. BTW: My neighbor and I each had a minor service issue with our lifts. The SL guys handled it right a way and at n/c.
Old Feb 25, 2007 | 01:08 PM
kww's Avatar
kww
I have a Superior Superlift SR7-H. Been very happy with it. The vendor was across from KSCC's spots at Carlisle. I would just be carefull of any product made in China and sold at the lower price. The quality of steel just isn't up to par with the US made. Don't know where you live in Pa. but I'm in West Grove and if it's close your welcome to check out mine.
Old Feb 25, 2007 | 01:10 PM
Patches's Avatar
Patches
First, here are a couple of threads I posted on my Bend Pak HD-9 installation.
http://forums.corvetteforum.com/show....php?t=1468748
http://forums.corvetteforum.com/show....php?t=1470876
I will only speak to the two types / brands of 4-post lift I am most familiar with - the AutoLifters which a friend of mine owned (AL now out of business but being produced by former AL employees - same design as the BYB) and the Bend Pak HD-9 I currently own. I spent many a weekend under the AutoLifters (7K lb. cap.) over a few years and have owned my HD-9 (9K lb. cap.) for less than a year.
The AL uses the fully boxed post section with collar-style crossbeam ends while the BP has a C-channel post design with internal runners that slide on ladder locks suspended from the top caps.
There seems to be a perception that the C-channels can spread under load, but that's not how these lifts work. There is virtually no side load on the posts and certainly nothing to splay the channels apart during raising or lowering. Basically, they are cable and pulley systems with crossbeam and column supports to manage the transmitted loads. What's important is that the members remain stationary (rigid) and no one corner binds - or lets loose - during the lifting or lowering process, destabilizing the equilibrium enough to allow one of the posts to tip too far.
The posts can actually tilt in/out a certain amount without destabilizing the lift and toppling it. I've seen this happen twice in person - once on the AL lift when one of the manual lever-actuated locks didn't engage while lowering and the other the first time I actuated my BP and one of the cables was still too loose. Both times, the tilt in the post was completely recoverable because the lift was not allowed to travel beyond one lock level. Remember that the entire mechanism is tied together with a tensioned cable system and tends to want to stay tied together rather than spread out.
I have noticed that neither design has more tendency for the corner attachments to decouple from the post or allow post tilt. Both designs are quite secure. What I have noted are the differences in lock designs which is the reason I went with my BP. The BP has a double lock system - the first is a pneumatically-actuated, "normally-closed" set of ladder locks. These are the primaries and the only way for these to allow the lift to lower is to keep one's hand on the release button and hydraulic release continuously and simultaneously until the lowest lock is passed.
The secondary, "slack-cable" set of locks are purely for safety. Should a cable break or go slack for any reason, that corner lock will release and automatically lock into the next detent, not allowing that corner to drop uncontrolled. This was the failure suffered recently by an AL lift with pictures posted here.
http://forums.corvetteforum.com/show...ht=autolifters
I'll qualify that link by saying that could have been prevented with proper maintenance and replacement of a faulty pulley setup that the manufacturer warned of. But it does illustrate that, ultimately, it's up to the owner/operator to safely install, maintain and operate his lift.
Also, high quality components and construction are vital when weighing the issues of cost and safety. My Bend Pak is made in America with solid engineering backed by decades of commercial lift design and construction, high-strength, high-quality components and great workmanship, including beautiful welds. The cost was comparable to it's competitors too.
I spent a lot of time researching lifts before ordering mine and I still believe I'd make the same choice today that I did when I chose the BP. Others have their own thoughts and opinions - and requirements. My decision was between the All American, the Revolution (Rotary), the Backyard Buddy and Bend Pak. Cost was not the primary factor, safety was. Check all the certification and testing that a manufacturer does on it's lifts - that alone is a very educational process.
Whatever your choice is, have a healthy respect for the potentially dangerous piece of heavy equipment that a lift is. Safety should be foremost on your mind always when working around a lift. That behavior alone should keep it a safe and fun piece of equipment to own.
As always, this is JMHO.
My buddy's AutoLifters. Note the collar-style beam ends.
The channel and ladder setup on my HD-9. You can see the air-cylinder-enabled main lock and the spring/lever pulley secondary safety.
The vette represents just a little over a third of it's rated weight capacity.
My dd parked under it.
Good luck with your decision and be safe!
Mike McCoy's Avatar
Mike McCoy
I just ordered the SS7000. $1944.00 delivered to Oregon, with casters, 3 drip trays, and jack platform.
Old Feb 25, 2007 | 01:27 PM
Novat_99's Avatar
Novat_99
Well said Patches....the BP & Rotary appear to have the same type of ladder setup inside the columns.
Tom
Old Feb 25, 2007 | 01:33 PM
MY03Vette's Avatar
MY03Vette
Patches,
What is your garage ceiling height? That garage door looks tall with you standing in it.
Old Feb 25, 2007 | 01:40 PM
bkemp's Avatar
bkemp
Thanks for the input, I see your posts are not bolted to the floor, you must feel comfortable w/ your Bend Pak
Old Feb 25, 2007 | 01:44 PM
Patches's Avatar
Patches
Door is 8 feet high with a 10-foot ceiling. Obviously, I can't park a pickup or taller vehicle under the vette but I still have a good 8" more to work with if I need it.
Here's a shot of the clearance I still have. The door opener is between cars so not an issue. The ceiling is the limiting height - parking the vette backed-in gives excellent clearance with the door raised.
Old Feb 25, 2007 | 01:48 PM
Patches's Avatar
Patches
I am planning on bolting the lift pads down this spring when it warms up. I didn't bolt it down immediately because I wanted to make sure I was happy with the initial placement. I am thinking of moving it in 4-6" and bolting it in there for a bit more clearance with the drive-on ramps when they are attached. They fit now but it's close.
Old Feb 25, 2007 | 03:08 PM
bkemp's Avatar
bkemp
Is the SS7000 a Superlift? Very good price for a lift " delivered ".
Old Feb 25, 2007 | 04:00 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
I'm going with the Bend-Pak for all the reasons Patches stated, AND the rolling air-jack option on the BP is over $1000 less than on the Revolution.
Old Feb 25, 2007 | 04:04 PM
oaks99's Avatar
oaks99
just to let you know all the lifts are basically made the same and there is quite a bit of difference between the 7000 # and tha 9000# units the ladder systems are made different .
Old Feb 25, 2007 | 07:45 PM
rkhegler's Avatar
rkhegler
Bill
Get a two post. IMHO.
To 4 Post Lift
