Thanks, this was probably the first mod I did to the vette
I removed the mirror to do the wiring. Installing the mount is as simple as removing the screw that holds the mirror and inserting the mount (it replaces the screw). I also ended up using a tad of locktite to keep it from "loosening up".
Beer
The one that i bought from ecklers <same part i'm sure> Well, it snapped off when i was screwing it into my rear view mirror.
Micah, I have the same mount as you currently have, i had that problem with the screw coming loose....just tighten it a bit more, perhaps try a lock washer.
The thing about this one is it positions the detector up in the tinted area of the window so it can't be readily seen from the outside, 99 out of 100 people won't know you have it. I took a strip of metal and made my own
Micah,
I would like to get more info from you on the issue with the screw loosening up. I have not heard that from anyone else. I have had one in my 2000 vert for almost 2 years, and it has not come loose. Sounds like somehing else is going on. Did you have the standard mount or the offset version for auto-dimming mirrors? If I sent you another, would you be willing to try it again?
Please PM me.
Thanks,
Rick
Originally Posted by mph1972
I had this one, it would not stop loosening up, even after I lock tited the screw and finally my visor clip broke, so I sold it.
I am looking at other options and have always returned to the one I posted above.
Chris
Everyone, I appreciate the comments. I am going to order this one and try it out.
Micah,
I bought for the Ecklers mount for 2001-2004 which is slightly different than earlier models. On this model you do not remove the screw that mounts mirror to the widshield. On this model you glue a plastic part into a receptical on the mirror mount. The bolt to attach bracket is (screwed) attached into this plastic part. The biggest problem I had was modifying the mount that came with the detector (Beltronics RX-65). I had a few minor issues with the Invisicord but the whole mount works great when you are done.
I've had the first one that attaches to the mirror for the past 2 years. It was okay, but I felt that the radar detector hung too low and slightly obstructed the view. Six months ago, I bought the second one that attaches to the Visor. I prefer this model. It's tucked out of the way and isn't as obtrusive. The only problem that I have with this one is that at high speeds on a bumpy road, it tends to vibrate and bounce a bit.
got the one from vettemod. Works great. wired into the mirror and not noticable from the outside. Gave up on the one under the mirror. Especially with the recent addition of my Garmin GPS.
