[Z06] Exhaust removal
Old Feb 27, 2007 | 03:27 PM
ls1mtz's Avatar
ls1mtz
Default Exhaust removal
How high did you have to jack up the back of your car to remove the stock Ti exhaust without cutting it? Going to be installing some Stingers soon and just wondering what i'm getting into.
Old Feb 27, 2007 | 03:52 PM
zeevette's Avatar
zeevette
About 3 feet
Old Mar 1, 2007 | 12:20 AM
SLPRC5's Avatar
SLPRC5
42 in. is better...
Old Mar 1, 2007 | 09:03 AM
ls1mtz's Avatar
ls1mtz
What are some ways that you guys got them so high without a lift?
Old Mar 1, 2007 | 09:47 AM
mymaur's Avatar
mymaur
I am sure there are some very creative ways to get your car nearly 4 feet off the ground. BUT, if you have any regard for your personal safety, go rent a lift. Many garages will rent their lifts by the hour. Very inexpensive and VERY safe.
2 cents
Old Mar 1, 2007 | 10:16 AM
l2vette's Avatar
l2vette
2 cents
Be safe, these cars are light weight, but not that light!!
Old Mar 1, 2007 | 10:17 AM
bluestreak63's Avatar
bluestreak63
2 cents
I did it a couple times and on the first attempt, when I was getting the car up near the height it needed to be, as I was pumping the jack handle one last time, the rear end started shifting. Needless to say I backed off and lowered it back down. If I had it do over again, I would find a lift.
Old Mar 1, 2007 | 11:41 AM
BRENRIT's Avatar
BRENRIT
If you have the means to do it yourself, try it but be safe. Sometimes just paying somebody to do an hours work is worth it.
Old Mar 1, 2007 | 11:42 AM
wamara's Avatar
wamara
Cruise-In II Veteran
2 cents
Or even just have a shop do it. It can be done in about a half hour; for $50 the safety is worth it.
Old Mar 1, 2007 | 12:09 PM
zeevette's Avatar
zeevette
I used the 4 jackstands method, which is much safer. I first raise the front about a foot, and secure it on jackstands, then raise the back end. This reduces the total angle you have, and it seems rock solid. It'll take you a couple of stages, but worth the effort for safety.
Old Mar 1, 2007 | 06:10 PM
chimazo's Avatar
chimazo
You basically HAVE to raise the front on stands, otherwise you'll touch the nose of the car to the ground because of the height you need to jack the rear.
I did mine on stands in the garage.
To Exhaust removal
