engine dies when put in gear
Old Feb 27, 2007 | 07:13 PM
DNO's Avatar
DNO
1st Gear
Default engine dies when put in gear
I have a 97 that has been sittin for about 3 mo's, I did put sta-bal in it. When I got in to start it it had a dead battery, I charged it & it fired right up. I let it warm up then put it in gear & it went about 3 ft. & quit. This repeated several times. I can rev it up & it will idel with no prob but as soon as it's in gear & start to move it quits. Fuel filter, fuel regulator?
Old Feb 27, 2007 | 07:18 PM
korte's Avatar
korte
You need to reset your keyfobs! The dead battery reset the fobs and the Theft deterrent system thinks the car's being stolen!
Old Feb 27, 2007 | 09:16 PM
steve badalamenti's Avatar
steve badalamenti
Even though the battery is fully charged, you need to disconnect it for a few minutes. Reconnect, and you should be OK.
To engine dies when put in gear
