[Z06] lube, oil and filter Question
Old Feb 27, 2007 | 07:31 PM
Marcs c5's Avatar
Marcs c5
Default lube, oil and filter Question
I just purchased my "new to me" Z06 about a month ago. I have not been driving it much so far, but with spring comming its time to go over everything and start out fresh. I will be putting in a new air filter and a lube oil and filter job along with checking all the rest of the fluids. One of my questions are how many zerk fitting are there and where are all of them? The next question is do I have to have the front end at a certain level to completely drain the oil? ( I thought I read this somewhere before).
Old Feb 28, 2007 | 01:13 AM
Bill Dearborn's Avatar
Bill Dearborn
No Zerks. Service Manual says to make sure car is level. Here are the Service Manual instructions:
Engine Oil and Oil Filter Change
Removal Procedure
Notice
To prevent leakage of oil filters, it is very important that you closely follow the installation instructions listed below or engine damage may result.
Important
Be sure the vehicle is LEVEL during this entire procedure.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Important
Allow a MINIMUM of 7 MINUTES for the engine oil to fully drain, once the engine oil drain plug and the engine oil filter are removed.
Remove the engine oil drain plug and allow the oil to drain.
Remove the oil filter by turning the oil filter counterclockwise and allow any remaining oil to drain.
Installation Procedure
Clean the gasket sealing area on the engine oil filter mounting surface with a clean, dry cloth.
Lightly oil the replacement oil filter gasket, use CLEAN oil.
Important
Use a cap-type wrench, AC Delco OF17W or equivalent, or a strap-type wrench with swivel handle to insure proper installation.
Install the filter by turning the oil filter clockwise. Tighten
Tighten the oil filter 3/4 to 1 full turn, after the oil filter gasket contacts the oil filter mounting surface.
Wipe the engine oil drain plug with a clean, dry cloth.
Install the engine oil drain plug. Tighten
Tighten the engine oil drain plug to 25 N·m (18 lb ft).
Important
Allow a MINIMUM of 3 MINUTES for the NEW engine oil to fully fill the engine oil pan.
Fill the engine with the proper type and amount of NEW engine oil. DO NOT use any engine oil additives in Corvette engines. For information on the proper type of oil to use, refer to Fluid and Lubricant Recommendations . For information on the engine oil capacity, refer to Capacities - Approximate Fluid .
Run the engine for 3 minutes and thoroughly inspect the oil filter and the oil pan drain plug areas for leaks.
Allow the engine to cool for a minimum of 3 minutes.
Recheck the engine oil level.
Top-off the engine oil to the full mark on the oil level indicator (dipstick).
Lower the vehicle.
Bill
Old Feb 28, 2007 | 06:14 PM
Marcs c5's Avatar
Marcs c5
Thanks Bill, I didn't think there were any zerks but just wanted to double check.
To lube, oil and filter Question
