Can I Hit 500hp?
Old Feb 28, 2007 | 09:52 PM
DBOYZ06's Avatar
DBOYZ06
Default Can I Hit 500hp?
Mods Are As Follows Cam, Lg Long Tubes, Fast Intake, 90mm Throttle, Underdrive Pulley, Vararam Intake. With These Upgrades I Pushed Out 453rwhp And 421trq. Next Week I Will Be Adding A Set Of Afr 205 Heads. So Do YOU Guy's Think It's Possible To Hit The 500 Mark.
Old Feb 28, 2007 | 09:59 PM
01QSZ06's Avatar
01QSZ06
what cam?
Old Feb 28, 2007 | 10:00 PM
DBOYZ06's Avatar
DBOYZ06
228/228 .590 Lift 113lsa
Old Feb 28, 2007 | 10:05 PM
DBOYZ06's Avatar
DBOYZ06
Old Feb 28, 2007 | 10:09 PM
01QSZ06's Avatar
01QSZ06
I'll vote no... probably another 20-30rwhp with the AFR's but you'll be close. Other guys getting 500 had cam's in the 240's and 215cc heads
Old Feb 28, 2007 | 10:39 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
nope.
and im also going to have to raise the BS flag if you think you are making 453rwhp on stock heads with only a 228 cam. 421tq?? i doubt it.
Old Feb 28, 2007 | 10:47 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Go with the TFS 215cc heads.
Have the fast port-matched to them.
You have a good chance of picking up 50rwhp with those 2 mods.
If not, you can try to squeeze every last bit out of it by doing minor mods like a better water pump, etc.
500 rwhp is attainable with that cam, you will definately at least get close. Don't get too fixated on a magic number.
I would not change the cam. That is a good cam, and any bigger might be over-camming the motor, and killing low end grunt/throttle response. I personally think cams bigger than yours in a stock displacement ls1 or ls6 only make since in a stalled-auto application. But I am certainly no expert, just a keyboard-jockey.
Old Feb 28, 2007 | 10:50 PM
_Will_'s Avatar
_Will_
They are ls6 heads, but those #s are definately on the high side for a 228cam without aftermarket heads.
Like I said though, don't get fixated with the pretty, round number of 500. You can get close, and close to 500rwhp through an m12 tranny and 3.42 gears will be awesome.
Old Mar 1, 2007 | 09:16 AM
angman5's Avatar
angman5
you better have them re calibrate that dyno how many stickers do you have on the car
Old Mar 1, 2007 | 09:38 AM
M6 Vetter's Avatar
M6 Vetter
Old Mar 1, 2007 | 10:02 AM
WKMCD's Avatar
WKMCD
nope.
I just made 500RWHP with a 234-240 112 cam. Of course that was on a fully built forged 402 with CNC'd L92 heads.
My fully built 346 with CNC'd stage 2.5R heads, 230-236 112 cam, ported FAST 90/90, LT's, etc, etc, etc made 460.
Phils C5 Vette (forum member) just dynoed 425/400 with a 228-228 114 cam, AFR's, LT's, ls6 intake, etc.
MCLEOD (forum member) just made about the same with the same setup.
KIDCID (forum member) 224-228 made a little more RWT than them and about the same RWHP through an automatic with the same setup.
These were all dynoed in the last month during a Dyno Day in our area.
453/421 - I doubt it but good luck!
Old Mar 1, 2007 | 01:03 PM
99 vett babycar's Avatar
99 vett babycar
Old Mar 1, 2007 | 03:28 PM
zeevette's Avatar
zeevette
Any dyno in the country is just a mouse-click away from any numbers you want. Don't blame the guy. The numbers game is everywhere.
Old Mar 1, 2007 | 06:54 PM
FixedRoof's Avatar
FixedRoof
lol.... or a spike in the graph or something.. not true numbers..
Kinda small... do some research... thats NOT overcamming an LSx... lol...
Last time I checked... a 228 cam is a SMALL cam in an 346cu LSx... LS6 243 heads still suck for flow, not much better than an LS1 241 casting head.
I agree with C5KIDD amd WKMCD BS flag is raised..
Post a graph... but if you've ever played with/seen the dynojet software up close... you can make it look however you want...
Old Mar 1, 2007 | 08:38 PM
vetred's Avatar
vetred
I noticed that you are sporting a well heeled "04" it DOES matter the question would have been yes you can but should you??? as before "02" it might have been quite a gamble with powdered rod and p.c.v. issues as well as others so the answer is what are the "grind" on the cam?? those heads are too small for the big 500 but find a real "Cali tuner" and you'll be close enough. AND 9 out of every ten that use the fast 90/90 have over done it on FLOW its about displacement and the 90/90 set up is a total waste on under 400 cubic inches YA YA I know but just Waite in about an other year when people start looking for more horse power someone else will say the same thing and everyone will say WOW ! Its just that right now its the latest thing and an awfull lot of tuners have bought a boatload of those things and they "must go".
Old Mar 2, 2007 | 01:10 AM
gogo4's Avatar
gogo4
nope.
You better keep the flag down boy. I have seen the dyno charts in person. Rick from synergy tuned this ride with great success...
Old Mar 2, 2007 | 01:27 AM
Mike94ZLT1's Avatar
Mike94ZLT1
The TRex is the only cam I know of to hit numbers like that on stock heads, and its far from 220- or 230- anything!
To Can I Hit 500hp?
Old Mar 2, 2007 | 07:26 AM
Retrotech's Avatar
Retrotech
IMHO It really depends on the Dyno, so many variations. SOP and MPH at top end of 1/4 mile is the real dyno. Peak numbers are over rated.
The heads alone will net a true 20 RWHP
A larger Cam will get you 15 RWHP
If you lower the Chamber CC to 11.5 to 1 Compression and use a tuning program such as HPT you will reach your goal.
You will not want to run this tune on the street.
It takes 45 seconds to change it once you are familiar with program.
Good Luck!
2003 Z06
GX5-3@114
205 AFRs
LG Longtubes
11.12@127
http://web.mac.com/meditateiveone/iW...20Run%202.html
Old Mar 2, 2007 | 09:12 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Dyno chart, or charts?
I am also not convinced these numbers posted, with the mods listed = the posted dyno numbers - that is if the dyno was on the up and up
Post these in the Tech Section - be prepaired with a flame suit
Old Mar 2, 2007 | 10:49 AM
C5 KIDD's Avatar
C5 KIDD
to be honest i really dont care who tuned the car. we all know how important a tune is, but even with all the tweaking, there is only so much power a certain setup will put out.
22X cams with heads usually put down around 400-420ish. where did the rest of his 50 rwhp come from?? basically youe saying he picked up over 100rwhp with just a small cam?? dont think so
lol... actually id love to see this over on ls1tech. they would have a ball with it.
also... for everyone saying its possible.... lets get a list of all the members we know with 500rwhp N/A with stock cubes
problem is he isnt actually at 450rwhp, so its not just going to take 50rwhp to get him there. i think with that cam and a nice set of heads, hes looking at maybe 450ish
RETROTECH.......... what numbers are you getting out of your setup?? thats a much larger setup than the 228 and LS6 heads. bet your not even at 450rwhp??
