windshield wiper
Old Mar 1, 2007 | 02:15 PM
caincarter's Avatar
caincarter
3rd Gear
Default windshield wiper
hi everybody im new here
but i have got a problem about 4 monts ago i bought my first corvette
a 1998 c5
about a week a go i started having problems with the windshield wipers
at first the would come up at random for about 10 seconds and go back down so i cleaned the drain udders(or so im told thats what there called) allot of crud came out and then things started getting words now everytime i start my car the wipers go up and just keep wiping and wont go back down
if anyone has any experience with this problem please help
Old Mar 1, 2007 | 04:02 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
This might do better in Tech. Here's a bump for ya.
Old Mar 1, 2007 | 05:44 PM
JCFILM's Avatar
JCFILM
That happend in my 02. Took it to the dealer and they replaced the wiper switch ($159 parts). They found the wiper switch shorted internally.
$311 was the total repair cost (My extended warranty through Warranty Direct picked up the entire cost for me)..
Make sure you pull the fuse for the wipers or they can scratch the windshield.
Old Mar 1, 2007 | 06:20 PM
Odd Dog's Avatar
Odd Dog
Default This happened to my '98 last april..
I took it to the dealer and they said the molding where the bottom of the windshield meets the black plastic tray was unseated and that the cowl drains (utters) were clogged. They took me right away but said I could have pulled the fuse for the wipers to make them stop.
Total price: $643.06
parts: motor
Screen as
arm - crank
labor
Hope yours is cheaper to fix - good side, this is the only repair on the car so far, having said that I have to go check now 'cause I'm sure I just jinxed myself!!!!!
Good luck
Old Mar 1, 2007 | 07:29 PM
JCFILM's Avatar
JCFILM
Originally Posted by Odd Dog
this is the only repair on the car so far, having said that I have to go check now 'cause I'm sure I just jinxed :
Only repair I had to do as well.
Old Mar 1, 2007 | 08:01 PM
QwkSlvrZ06's Avatar
QwkSlvrZ06
More than likely its just the wiper module. They have always given GM some problems. I'm pretty sure these are serviceable on your car. It is located under a plastic cover on the wiper motor housing. You may or may not have to remove the wiper arms to remove the cowl screen. I haven't had one apart on a vette in a while. You should be able to fix this for under 50 bucks if you do it yourself.
To windshield wiper
