Removing body side molding
Old Mar 2, 2007 | 11:45 AM
belted's Avatar
belted
6th Gear
Default Removing body side molding
I'm going to buy a C5, but I don't care for body side molding. More than half the cars I've looked at have BSM. Is there an easy way to remove the molding without ruining the paint underneath? Thanks!
Old Mar 2, 2007 | 11:59 AM
boyblue97's Avatar
boyblue97
just run a search, i know ive seen it on here before... Yes you can do it hopefully someone that has will chime in and tell you how otherwise just search it
Old Mar 2, 2007 | 12:10 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I used a hair dryer to take off the long piece to reposition it after the body shop guy put it back on a little crooked. You will need to use plastic blade or credit card to get it started off then just pull while heating it up some. Some people use fishing line but I didn't.
Old Mar 2, 2007 | 12:15 PM
travelingypsye's Avatar
travelingypsye
You will need to roll off the tape while using a hair dryer. You WILL get blisters on you thumbs & index fingers from rolling off the old tape......
Old Mar 2, 2007 | 12:18 PM
belted's Avatar
belted
6th Gear
I did a search as boyblue97 suggested, and it looks like it's pretty easy. Heat and a little patience with some fishing line. That cetainly opens up the market as to what is available. Thanks for the tips!
Old Mar 2, 2007 | 12:30 PM
KeyoRacing's Avatar
KeyoRacing
Hi if you decide you don't want the molding I'd be interested in taking it off your hands. drop me a line
keith
Old Mar 2, 2007 | 07:27 PM
T VETTE's Avatar
T VETTE
Couple of thoughts:
1) If your car is a few years old and especially red you may see a line as the paint under the moulding is like the day it was new and the exposed paint has some fade. (My avtar is old, mlds still on.)
2) I did not like mine either, but only removed the mld from the fender vent area and left the door side on for protection. Looks good I think and probably the way it should have been done by GM. Try it first.
I also used a heat source, heat it up good, don't blister the paint, and if you pull it off carefully most of the adhesive stays on the mld. Let us know how it went.
I should mention that a body shop would have a special heat gun that is much hotter than a hair dryer, they may only charge a small amount and do this type of work every day. Maybe 1/2 hour labor each side.
Old Mar 2, 2007 | 08:34 PM
MyOwn69's Avatar
MyOwn69
Oh, Gawd, I can't believe we're gonna' go through this again!
Seriously, SO many have done this that it should NOT be an issue any more.
What is the worst color? I was told it was Millinium Yellow - yet I did it anyhow.
How long after it was new? I did mine 4 years after "birth."
Will it show? Didn't for me!
How did I do it? (Gawd, I'm sounding like Donald Rumsfield! )
I used WD40 and 30 lb fishing line. I did hit it with the blow dryer for a bit, but if the weather is not too bad (read: cold!) you probably don't need to.
Simple, really: spray WD 40 - use the fish line (30 lb) and that should do it.
CLEAN UP - some "Goo-B-Gone" or more WD40 took care of the adhesive on the door, then whatever you use to make it the most sparkling car in the lot!
CLIFF NOTES: Fish line (30 lb) - WD40 (lube factor!) - take your time!
Old Mar 2, 2007 | 08:36 PM
jrose7004's Avatar
jrose7004
Use a hair dryer, fishing line and some Goof Off.
Old Mar 2, 2007 | 08:37 PM
MyOwn69's Avatar
MyOwn69
Like I said!!!
Old Mar 2, 2007 | 09:24 PM
rkhegler's Avatar
rkhegler
Here is how I did mine.
I got a really long sharp kitchen knife and had my buddy pull the piece away from the car with his fingers starting from the end on the door. Run the knife along the molding (be careful not to get it against the car). It came right off. Once I had it removed, I used some WD40 to remove any of the sticky residue left on the car. It took all of about 20 minutes total. No kidding. Good luck.
Old Mar 2, 2007 | 09:28 PM
divitasbluepitbulls's Avatar
divitasbluepitbulls
Mine came off so easily that I literally ripped the paint off and it cost me 400.00 to get it fixed. No matter how easy it seems to come off take YOUR FREAKIN TIME! Do do what I did. I almost committed suicide becasue of that!
divitasbluepitbulls
Mine came off so easily that I literally ripped the paint off and it cost me 400.00 to get it fixed. No matter how easy it seems to come off take YOUR FREAKIN TIME! Do not do what I did. I almost committed suicide because of that!
Old Mar 2, 2007 | 09:32 PM
belted's Avatar
belted
6th Gear
Looks like heat, fishing line, WD40 or Goof off, and patience is the way to go. Thanks for the help!
Old Mar 3, 2007 | 06:47 PM
KeyoRacing's Avatar
KeyoRacing
Still ....if anyone doesn't want their molding I'd be interested in taking it off your hands.
Old Mar 3, 2007 | 08:27 PM
moserbe's Avatar
moserbe
Save a tree, keep your molding.
Old Mar 3, 2007 | 08:53 PM
Vassili's Avatar
Vassili
NO KNIFE... are you crazy man? Use fishing line and some Goof Off or Oops.
To Removing body side molding
Old Mar 3, 2007 | 09:40 PM
jetske's Avatar
jetske
However you get it done, it's the right look!
Old Mar 3, 2007 | 09:46 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Old Mar 3, 2007 | 10:31 PM
Use a hair dryer to heat the tape holding the molding to the side of the car, then use some strong fishing line to saw through the tape. Best to have a helper that can keep a little outward pressure on the molding as you progress down the side of the car. Once the molding is removed, the remaining tape/adhesive can be removed with some WD-40 or Goo Gone.
