AC compressor started squealing
Old Mar 2, 2007 | 02:42 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Default AC compressor started squealing
Can the clutch be replaced, or do you have to replace the compressor?
Anyone know the cost to repair?
Old Mar 2, 2007 | 03:46 PM
sigma6's Avatar
sigma6
i want to know too.. i have same prob
Old Mar 2, 2007 | 03:55 PM
Corvette Don's Avatar
Corvette Don
Does it squeal with the a/c on or off?? If its only when you kick the a/c on it could be the tens.(i dont remember if the the a/c comp. has a belt tens. or not), if not then the belt is loose allowing the belt to slip around the a/c pulley causing the squeal (when the comp. is engaged)
Old Mar 2, 2007 | 05:05 PM
Ron C!'s Avatar
Ron C!
Just did this. Had a squeak with A/C on, repalce all the belts and tensioners. Still squeaked. Replaced the compressor, dryer and orifice tube. Plan on doing a water pump too since it has to come off to remove the compressor. I found the cheapest price in the country here:
http://cgi.ebay.com/ebaymotors/97-04...7433QQtcZphoto
They tell you that some cars, 2000 and older I think, require a replacement bolt for the conpressor installation. I didn't need it after all, but have it if your car needs it.
Old Mar 2, 2007 | 09:01 PM
JeepTJ's Avatar
JeepTJ
Yes, It squeals with the AC on and off. When I turn the AC on it changes, when you turn it off it gets louder for a few miles.
Old Mar 3, 2007 | 05:02 AM
KeyoRacing's Avatar
KeyoRacing
Is this something with the car... i had the same issues for about 2 weeks ...changed the belts and it's ok now but it seems a lot of people are having these problems
Old Mar 3, 2007 | 09:38 PM
NEVERL8C5's Avatar
NEVERL8C5
Purchased mine from the same place as Ron C great transaction and very responsive to inquiries. I would replace the tensioners first. I did both when I installed the new engine.
Old Mar 4, 2007 | 10:37 AM
Toms2001PewterC5's Avatar
Toms2001PewterC5
If it squeals with both the compressor on and off I doubt that it is the compressor. When the compressor is off the only thing rotating is the pulley. My guess is it is either the compressor pulley bearing which can be replaced or the belt.
To AC compressor started squealing
