Need Advice Installing Some Bling
Old Mar 3, 2007 | 01:12 PM
82Collectors's Avatar
82Collectors
Default Need Advice Installing Some Bling
I've seen many pictures of C5's with a decorative exhaust plate and bought one last spring but never installed it on my '98 becuase of the mounting surface. The plastic mounting surface is has ridges which gave me concern that there is not adequate bonding suface for the sticky adhesive to maintain a permanet grip. Not only is it an irregular surface, it is not fully flat as you can see toward the top of the photo where an angle begins.
Are all C5's like this and did anyone do anything different other than press the mirror metal plate onto the plastic surface. My plate is from SS Inserts and has a 3M peel and stick back.
Appreciate anyones advice when I try and install it - when the weather warms up and snow is gone
Old Mar 3, 2007 | 01:31 PM
va-c5's Avatar
va-c5
i was skeptical like you at first..my thought was how is that going to stick?i cleaned the serface area with alcohol and peeled and stuck it on
well that was last july and its still on there....so the strips of tape are right on ....here is a pic
Old Mar 3, 2007 | 01:45 PM
spiral04's Avatar
spiral04
After you clean it you could also use a little 3M spray glue. I taped off the lower areas so they didn't get glue on them and then installed the plate as the directions stated. I don't think it was necessary, but I too had my doubts. No probs so far...
Old Mar 3, 2007 | 02:39 PM
They all look just like yours. Clean the surface really well, and once you stick that two sided tape down, it will hold very, very well. I've had my exhaust plate on for over 5 years and I think I would need a chisel to get it off.
Old Mar 3, 2007 | 02:57 PM
chevyvette1's Avatar
chevyvette1
no problems with them sticking on, the only thing I noticed with your plate is the C5 logo is upside down, all of the plates I've seen and including mine, has the wider part of the plate on top,
here are some pics to help explain what I mean
http://www.westcoastcorvette.com/s-7...st-Plates.aspx
Old Mar 3, 2007 | 03:07 PM
vetred's Avatar
vetred
Bling,....ya,...thats cool. Im spending a LOT of money on bling but,....none of it makes it to my car. It ALL goes to my wifes fingers or ears and neck,.....then when I want to put something "scary looking" on my car she says, "oh,....thats nice"
Old Mar 3, 2007 | 03:15 PM
82Collectors
Thanks everyone.
I'll give it a go in a couple of months when the weather gets into the 60's.
I guess they make the plates both ways.
http://www.ssinserts.com/index.php?m...ort=20a&page=2
Old Mar 3, 2007 | 03:18 PM
steve8's Avatar
steve8
Definitely wait for some warmer weather, clean it up, and you should be good to go.
To Need Advice Installing Some Bling
