Help !Door Lock Question
Old Mar 3, 2007 | 08:37 PM
Ta-taaa's Avatar
Ta-taaa
Default Help !Door Lock Question
Help!!
My drivers door lock is not working right.
When I lock my door with the remote, my drivers door will not lock.
If I manually lock the door, it of course, it's locked.
When I use the remote to unlock the car, the drivers door will unlock.
Do I just have a door lock solenoid??
Any ideas??
Thanks!!!
Old Mar 3, 2007 | 08:48 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
what happens with the power lock switch in the car?
Old Mar 3, 2007 | 10:10 PM
Ta-taaa's Avatar
Ta-taaa
Same thing.. Door won't lock. If you manually lock it, it will unlock with the switch inside
Old Mar 3, 2007 | 10:50 PM
ScottSuff's Avatar
ScottSuff
Cruise-In VI Veteran
Cruise-In VII Veteran
Sounds like the common problem in the C5. If you do a search for it you'll see a number of postings. This is a very detailed posting. Check it out.
http://forums.corvetteforum.com/show...control+module
I did the repair on my 02 and it's still working.
ScottSuff
To Help !Door Lock Question
