[Z06] rear end ?'s
Old Mar 3, 2007 | 08:51 PM
bluzohh6's Avatar
bluzohh6
7th Gear
Default rear end ?'s
Question Do I need to get a new rear end if I run a drag radial? The rear end went out once already with the d/r. What can I do to make the rear end stronger, and why does the upgraded rear from dte come with only the right hardened output shaft? Right now the car is stock other than a blackwing, and d/r's. My longtubes and exhaust just arrived today. Help so this doesn't happen again!!!Please
Old Mar 3, 2007 | 09:16 PM
MislMan's Avatar
MislMan
Probably a good idea to get a rear end brace from Dyno Tech Engineering - DTE (a board sponser) to help hold the cases together.
Later ... Larry S.
Old Mar 4, 2007 | 04:30 AM
bluzohh6's Avatar
bluzohh6
7th Gear
anyone else care to answer give a second opinion if you will?
Old Mar 4, 2007 | 06:25 AM
Ranger's Avatar
Ranger
Might want to have a look at this thread:
Preventing Breakage--Driver Errors to Avoid
Ranger
To rear end ?'s
