Rotor issue
Old Mar 3, 2007 | 10:34 PM
Zeke Z's Avatar
Zeke Z
Default Rotor issue
I'm going to change out my rotors tomorrow. I pulled off three of the old ones with a little help from a rubber mallet but the driver side rear won't budge. The ER brake is not on, is there anything else that would prevent it from just sliding off??
TX
Zeke
Old Mar 3, 2007 | 10:59 PM
T VETTE's Avatar
T VETTE
If you are going to replace, hit it with a ball peen hammer between the studs a little. Spray WD 40.
Old Mar 4, 2007 | 02:36 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
hit it between every other stud and go 360 degrees around the rotor. it will eventually break loose.
Old Mar 4, 2007 | 03:58 PM
bighank's Avatar
bighank
Default Get a BIGGER HAMMER
NO KIDDING . I used some rust penetrant. PB Blaster works better than WD40. Whack it all around fron the rear and also the front.
It WILL COME OFF BIGHANK
Old Mar 4, 2007 | 04:08 PM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Just work it
Paul G.
Old Mar 4, 2007 | 04:39 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Zeke: the rear drivers side for some reason has a tendencey to stick. The brake dust tends to lock the brake shoes for the e-brake. gently tap the shoe for the e-brake all around on the back side of the rotor, then the rotor from the outside in and then from the inside out . This should brake it loose. If your still stuck call me you got the number.
Old Mar 4, 2007 | 05:09 PM
Bill Dearborn's Avatar
Bill Dearborn
My Tahoe has a similar style rear brake. If it has been a long time since the rotor has been off you may have dirt/corrosion build up between the inside edge of the E brake part of the rotor and the E brake shoes. If you are trying to pull the rotor over this crap good luck. The only way I got the Tahoe rotor off was to put the claws from a claw hammer into the rotor vents and then hit the claw hammer with a heavy sledge hammer. Worked my way around the rotor and in about 15 minutes it was off. Due to winter weather and road salt and sand here in the Northeast sledge hammers are a must have tool when doing brake jobs on most cars.
Bill
Old Mar 6, 2007 | 01:08 AM
Zeke Z's Avatar
Zeke Z
Thanks for all the feed back. The WD and the new blaster I picked up at the Vette Fest in Chicago Sunday did the job.
Called Mitch over at FLP this morning ordered the new Baer Eradispeeds and new pads. Hurry up UPS.
Thanks again
Zeke
To Rotor issue
