Hi Zosixin. I'm pretty much saturated by the DVD production effort. Once it goes to distribution, I hope to make some stops at a few track rentals around the country and meet with owners seeking max acceleration. So when the time comes, let me know if the Vegas owners want to host a rental and make some passes in Corvettes. I suspect they'd shed some tenths in an afternoon.
Considering street tires (I run 18" BFG KDs) that aren't heated and a lack of water there, what RPM range and PSI do you recommend I practice with for this technique? I'd like to do some of this to practice but I certainly don't want to risk any breakage. I normally run 27psi in the rear and 35 in the front for street driving.
Sort of goes back to my stoplight question I guess
You're not likely to break anything on street tires.
The easiest way to learn launch is to get a Gtech Pro, properly calibrate it, and find a very safe spot to make and measure some acceleration runs.
The principles involved in launching are the same at the track and the street. The variables are the launch rpm, the clutch release and the throttle squeeze. The driver must always optimize the relationship of those variables to the surface conditions and platform.
That's where the Gtech comes in. I'll cover that on my DVD.
Ranger, was just lookin at ur track link, you ever win the gamblers race?
I've chosen to focus on the driving component of a traction-limited manual tranny stock car. In that pursuit, bracket racing is a distraction for me. And the auto-tranny drivers reign supreme.
So other than occasional match races, I refrain from (bracket) racing.
Ranger, I think you've hit the nail on the head declaring that you have to depress an LS6 clutch rapidly... It took me 6 months to figure it out; I was blaming my C6Z shifter, the clutch itself, the shifter installation, etc. It's weird.
Ranger, I think you've hit the nail on the head declaring that you have to depress an LS6 clutch rapidly .... Anyways, thanks for your help back in November.
Glad it worked out for you. Sometimes the solution comes through late night collaboration.
Using Ranger's launch tech, and some personal coaching/insight, I was able to obtain my 11.71 on drag radials my 5th pass. So the tech works well, thank's Ranger.
Robert
You might try wearing a sports glove on your right hand.
I went that route in the summer of 2001 when my hand came off the shifter on the 2-3 and hit the dash. After examining gloves of every description and trying a few, I've settled on a Nike Receiver/running back glove (model # GF0030). Hard to find this time of year. But a Nike or UnderArmour batting gloves are similar in effect. The slight padding and positive control give good grip with the fingers on the 1-2 and 3-4 and firm confidence on the 2-3.
Ranger
Good grief man!! You have this down to hard-science. I hereby nominate you for the Corvette Forum Honorable Doctorate - henceforth to be known as (start echo):
It's all about discovery. The techniques that yield max acceleration can come from (1) personal experimentation or (2) a trusted source.
I've worked hard for six years doing the R&D to learn successful techniques and procedures. The real magic is they can be learned fairly quickly and can innoculate drivers from otherwise common breakage.
Ranger
I could not agree more with this. I jumped on the "Ranger bandwagon" about 1.5 years ago - reviewing my spreadsheet of my runs (as suggested by Ranger) I can see the dramatic improvement taking a somewhat scientific approach takes to this. And, it really doesn't take long to get the basics down, if you're willing to listen when someone with more experience tells you something worth learning.
Ranger, another thing - you have saved me, and surely many others, a fair amount of money. I nearly bought a shifter for my C6, decided to search the Forum, found your post on shifting, and hardly miss a shift. I also was going to buy a high dollar clutch for my H/C C5, however, again watching your success I went with the LS6 clutch with no problem (none either with my LS2 .... knock on wood). Better to mod the driver before the car.
Sidebar - to the person asking about running open headers - I have cutouts on my C6 before the catback, and have found no gain at all at the track. Since I have HP Tuners and scan runs, I have adjusted fuel and spark for them but no change. I believe the factory catback is pretty efficient. Here is more detail and pics on that if anyone is interested.
^^^ Joe, you've got a great story of the progress that can by made by focusing on the right elements. Sort out the driving and then get the most from the right mods as they're added. Minimize unnecessary expenses along the way.
The NHRA publishes correction factors for ET and Trap Speed for tracks at various elevations around the country. You can use that chart to compute a goal for your car in comparison to cars running on tracks at lower elevation.
Just remember that the adjustment is made based on elevation alone, not weather.
NHRA cites the Tucson race facility as 3000'; it's the location of some Lucas Oil Div 7 events. You would use the chart for Stock & Super Stock.
In Maryland the fuel is 93 octane. That's what I use. I tried a few gallons of 104 Sunoco at the track once, when I was nearly out of gas amid passes. I promptly lost about a tenth on the higher octane fuel. MIR is at 80' elevation.
Ranger
Hi Ranger! Firstly, I'd like to thank you for your excellent contributions to the Corvette community. Your knowledge and expertise is definitely an asset to us all.
I have a question regarding altitude correction: I live in an an area 3300' above sea level. My best pass was run on a night with 4700' density altitude.
When converting my timeslip ET & MPH, do I convert using the 3300' factors, or the 4700' factors?
...I have a question regarding altitude correction: I live in an an area 3300' above sea level. My best pass was run on a night with 4700' density altitude.
When converting my timeslip ET & MPH, do I convert using the 3300' factors, or the 4700' factors?....
Thanks for your kind words.
You would adjust your ET & Trap speed using the 3300' elevation of your track.
Drivers at all tracks must contend with weather; it's the major elevation differences these correction factors are intended to deal with.
Thanks for your service brother! The school is opening again to CS, CSS, 10 years too late for me as I am way too old for that now ...
Thanks to you, Dave for your service in the cause of freedom.
Regarding ranger school, the physical demands are such that very few men beyond late-20s ever make it to graduation. Calorie and sleep deprevation exact greater tolls on recovery time as you get older.
I'll be in your neck of the woods later in April. Will shoot you a PM.
