Battery specs?
Old Mar 5, 2007 | 11:08 AM
DrWorm's Avatar
DrWorm
Default Battery specs?
I'm trying to sort out some problems and was wondering if an Optima 750CCA / 950CA is a sufficiant battery for the C5?
My battery volts hang out about 13.6-14.2
Old Mar 5, 2007 | 01:59 PM
JEEP/C5's Avatar
JEEP/C5
Either one will be fine, just make sure you get the right size to fit in the hole. Im looking into the Odyssey battery since they are very light weight but are lower on cca. Factory battery is 38#, some optimas are 42#? + and the Odyssey's are 15# for 690 ca (not cca) and 25# for 925 ca (not cold cranking - it think it was rated at 80 deg. cranking). so may not be a good for a daily driver (esp. one in colder climates) but would be great for a weekend ride like mine.
