Hey how about this: a rocker panel saver that is lighter than any metal.Corrosion & chemical resistant , wear resistant, non toxic, self lubricating ,UV and static resistant,vibration and impact resistant,can be recycled.Solid colour all the way through. No paint or powder coating to flake or peel off at first scrape of a speed bump. Tested in CRYOGENIC conditions with no impact. Low coefficient of friction . Precision CNC made with ULTRA HIGH MOLECULAR WEIGHT space age material .Gives you 1/2" of buffer between your expensive rockers and speed bumps or steep driveways.
Is that groove milled into the puck for a jackstand? Does it work well? I have thought about doing something like that.
Uh your getting close. Yes that is some of my handy work. I didn't like the idea of jack stands with proper safety pucks so I made these and make them for other forum members as well.
Hey another great guess .I like this game. One person has been really close. The first one that comes up with the exact answer, I will make you a set and send them shipping and all.
If I was going to make them out of "plastic" that's what I would use. Performance characteristics are high impact strength and weather resistant. I know you can get a 1/2" x 1" piece 5 feet long for $16.21. A 1/2 x 1-1/2" by 5' is $18.67. It's an easy material to work with
Black UHMW- Ultra HIgh Molecular Weight Polyethelene.
Light, only half the weight of Delrin. Great abrasion resistance.
Has the same coefficient of friction as Teflon (PTFE).
Hard to hold close tolerances, but shouldn't be a problem on this part.
Great idea.
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
