check engine light
Old Mar 6, 2007 | 06:07 PM
50vette03's Avatar
50vette03
Default check engine light
I have and 03 automatic c5. I put a vara ram and flowmasters on it. My check engine light came on while i had it at the track. It is still under warranty so I took it to the dealership. They said the motor is taking in to much air bc of the vara ram and it is leaning the motor out. They said the only way to fix it is to take the vara ram off or buy a diff maf. But if I buy another maf, it will void that part of the warranty and so will dyno tuning it. Any ideas or help would be greatly appreciated
Old Mar 6, 2007 | 06:15 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Do remember hitting the rev limiter at the track? THAT will lean the engine out momentarily and throw those codes.
The dealer is full of crap... They haven't any idea why the lean codes were thrown, so they followed your lead when you mentioned to Vara Ram...
Old Mar 6, 2007 | 06:16 PM
steve8's Avatar
steve8
Clear the code for now and see what happens.
Old Mar 6, 2007 | 06:20 PM
50vette03's Avatar
50vette03
Yes I did hit the rev limiter. So do you think I should just leave it on there? What do I need to do to get the problem fixed? Thanks for your help
Old Mar 6, 2007 | 06:41 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Start here:
http://97vette.com/howto/codes/index.html
Follow the procedure for bringing up the code and post the info back here. There are a number of things that can bring about a CEL. Many are harmless. Once we have the codes we can help you diagnose and fix the problem.
Paul
SSWEET's Avatar
SSWEET
Oh No! Sounds like yer gonna hafta git one of those NASCAR Restrictor Plates...pronto...
Old Mar 6, 2007 | 07:21 PM
50vette03's Avatar
50vette03
thanks for the codes but mine is an 03 and the codes are for an 97-00. I dont know what the codes are thought. He just told me what it was doing. If I clear the codes I will still have the problem. So what should I do. Besides sell it. lol
Old Mar 6, 2007 | 07:25 PM
beav626's Avatar
beav626
Most of the codes on that list should apply to your 2003. If there is a serious problem It will show up again after you clear the codes. Try that first and see what comes up next...
Good luck
Old Mar 6, 2007 | 07:31 PM
Glennm27's Avatar
Glennm27
There is NOTHING wrong with your car.
Follow this procedure to see the codes.
Turn the key to the ON position, but don't start the engine.
Clear any present messages by pressing the RESET button.
Hold the OPTIONS button down, and press the FUEL button 4 times.
This will get you into the CODES section of the DIC.
The computer will automatically display all the codes your car has created.
It will cycle through each code every 3 seconds.
Any code that ends in H is a history code (something that has occurred in the past) but is fine now.
Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode.
It should start with a module and show "NO CODES" or "# CODES".
Do this then to reset and clear all codes.
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES".
Press OPTIONS to go to the next module.
Repeat the steps in this paragraph until you have reset the codes in all the computer modules.
The lean codes are 1071 & 1074. You'll see them scroll through when in the PCM module.
Just clear em all, the Check Engine light with go out and all will be fine
Old Mar 6, 2007 | 07:41 PM
talon90's Avatar
talon90
NCM Ambassador
We know you don't know. We want you to follow the procedure and read them so you can tell us what they are. Help us help you. Most of the codes (read 99 percent) from the '97 - '00 will apply to your '03.
Old Mar 6, 2007 | 08:27 PM
50vette03's Avatar
50vette03
Thanks for everyones help. This is alot better that the dealer. Once I get these codes and clear them that still doesnt fix my problem does it? This is my first vette so I'm clueless. thanks again
Old Mar 6, 2007 | 11:30 PM
GrayC5's Avatar
GrayC5
thanks for the codes but mine is an 03 and the codes are for an 97-00....(snip)....
The following web site has the DTCs specific to each model year. After selecting your model year, click on READ MORE toward the bottom of the next page that appears to review all the codes for your model year.
Corvette Computer Codes and DTC Information
Old Mar 7, 2007 | 12:20 AM
WWK888's Avatar
WWK888
If there is an H after the code it means it is History...don't worry about it. If it has a C then it means it is current and the problem is ongoing.
Old Mar 7, 2007 | 12:21 AM
jrose7004's Avatar
jrose7004
Try that, it may not come back!
Old Mar 7, 2007 | 09:27 AM
Glennm27's Avatar
Glennm27
If you hit the rev limiter and leaned out the engine, it will throw those codes MOST of the time. You hurt nothing and the codes will not return if you do not hit the limiter again.
Your problems will most likely be over with.
When you reset the codes, the Check Engine light will go off. If it does not return, you're in the clear. I'd be willing to bet it will NOT return.
Old Mar 7, 2007 | 09:29 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Good idea! Let us know what happens.
Thanks,Matt
Old Mar 7, 2007 | 04:15 PM
50vette03's Avatar
50vette03
Default I have the codes
OK guys. Just got off the phone with the dealership. The codes are
PO101
PO102
PO171
PO174
Should I take it and have it dyno tuned. I'm getting it done for $300 by MTI. Thanks
To check engine light
Old Mar 7, 2007 | 04:26 PM
Laguna Blu's Avatar
Laguna Blu
PO101
PO102
PO171
PO174
Can't hurt to have it tuned and you didn't tell us if the codes are current (C) or old (H).
Old Mar 7, 2007 | 04:28 PM
50vette03's Avatar
50vette03
That was all the dearship told me.
Old Mar 7, 2007 | 04:29 PM
chaase's Avatar
chaase
St. Jude Donor '12
PO101
PO102
PO171
PO174
Have it dyno tuned. I had the exact same issues with my halltech stinger when I would drag race mine. I would only get the codes at the track (never on the street). The tune will give you better performance and you can get the shifts firmed/speed up. It adds a great deal to A4's
