[Z06] zero oil pressure WTF?
Old Mar 6, 2007 | 10:47 PM
Z064FUN's Avatar
Z064FUN
Default zero oil pressure WTF?
Common sense says it is the oil pump but I have read about sensor failure. I'm not about to run it but is there another way to check oil pressure? I'm open to any suggestions. Thanks in advance.
Jade
Old Mar 7, 2007 | 12:19 AM
Dr Feelgood's Avatar
Dr Feelgood
Jade
PM Ja03C5 he might have an answer for you. He found his wiring harness melted. After he replaced numerous oil sensors. That is all the info I know, I'm sure he'll be glad to help you with the rest.
Old Mar 7, 2007 | 01:08 AM
heavymetals's Avatar
heavymetals
If you start it and it doesn't knock, you got pressure.
The sensor is fairly easy to replace.
It is on the top at the rear of the motor.
Old Mar 7, 2007 | 01:25 AM
striper's Avatar
striper
If you had no oil pressure by the time the gauge showed zero you would have been experiencing other symptoms, such as ungodly engine noises. Faulty sensors have been extremely common, I had it happen myself. I'd bet it's most likely that. It's not too difficult to replace. Unfortunately it's in an inconvenient place to get to.
Old Mar 7, 2007 | 10:19 AM
FasterIsBetter's Avatar
FasterIsBetter
Wouldn't hurt to stick an oil pressure gauge on the engine and check the pressure. If you have pressure, then it's either the sensor or the circuit. It's always a good idea to verify that you actually do have sufficient oil pressure before assuming it's a bad sensor.
Old Mar 7, 2007 | 12:04 PM
ctheusa's Avatar
ctheusa
doesnt the faulty oil pressure sensor usually show pegged?
Steve
Old Mar 7, 2007 | 01:39 PM
ptindall's Avatar
ptindall
Steve
That's what I thought. 130psi. Can it read zero when it fails too? Did it also throw warning lights and a DIC message. I bet the ECM would not allow the engine to run if it was reading zero pressure too. I don't know about the LSX, but the LT-1 had a separate sensor for the ECM and the gauge. If you have a good scanner, you could plug in and see that the ECM is reading.
Old Mar 7, 2007 | 02:01 PM
heavymetals
Steve
No it doesn't. ZERO when mine failed.
Scared the crap out of me too as I was booking it.
Even if you put an external pressure indicator on it, your gonna have to start it, or at the very least turn it over till it builds pressure.
I guess you can disconnect the coil packs to prevent it from starting.
I didn't (lucky or blessed?) and it ran fine, just no pressure indicated.
Bad sensor.
My heart started beating again once that was determined!
Old Mar 7, 2007 | 09:56 PM
ctheusa's Avatar
ctheusa
that would be enough to scare the crap out of you ...mine pegged when it went and most ive heard did the same.
corvette oil sensors are like a box of chocolate you never know what youre gonna get.........forest gump
Old Mar 7, 2007 | 10:16 PM
heavymetals
info:
Ref#4 is the oil pressure sensor.
Old Mar 7, 2007 | 10:25 PM
Sick Z06's Avatar
Sick Z06
You can also push the accelerator to the floor while cranking it, and that will trigger "flood clear" fuel cut.
Also someone posted here a while ago about an Oil Pressure relocation procedure to make future replacements alot easier.
To zero oil pressure WTF?
