Upgrade to 01+ MAF?
Old Mar 7, 2007 | 10:38 AM
C5 Corvette's Avatar
C5 Corvette
Default Upgrade to 01+ MAF?
Having a 98 are there benifits to upgrading to a 01+ MAF and if so how can you go about doing that? Does it just bolt on and is that safe to do?
Old Mar 7, 2007 | 06:16 PM
C5 Corvette
bump
Old Mar 7, 2007 | 08:56 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It's certainly possible, but unless you're heavily modified and already making big hp, it will serve no real benefit.
The MAF isn't that much of a restriction on the intake, so "just bolting it on" a mostly stock car won't gain you much, if anything.
Since the 01/later MAF's incorporate the IAT sensor, there is some conversion and tuning changes that need to be made in order to make the swap.....more detailed info here:
http://ls1howto.com/index.php?article=25
Old Mar 7, 2007 | 09:15 PM
WKMCD's Avatar
WKMCD
Your sig says your car is stock. There is no benefit to changing the MAF unless it becomes a restriction - probably in the 450RWHP range. As was said tuning is definitely required for the change.
I did but I haven't been stock for a long time.
To Upgrade to 01+ MAF?
