Initial impression with 187 deg t-stat
Old Mar 7, 2007 | 07:50 PM
Mach2's Avatar
Mach2
Default Initial impression with 187 deg t-stat
98 6-speed with 44250 miles. Got the C5 mid Jan 07 and decided to take advantage of the local Dealers coupon for cooling system drain, flush & fill. Had the upper & lower radiator hoses replaced too. I bought the 187 degree thermostat from Summit. I don't like the 160 degree t-stat, seems the stat would be open all the time and not allow the radiator to cool the coolant. The weather is warming up here in Central Calif so I went for a scoot after picking up the C5 after the work was done. I notice the temp gauge needle was a tick over the 200 mark, and the gauge button showed 198-205. The stock 197 deg t-stat I had removed kept things at, or just below, the 200 mark and 196 with the gauge button. I'll use the Hypertech III to lower the temp settings the fans come on because with the 187 deg t-stat, the water is flowing thru the radiator sooner than before and the radiator isn't cooling the coolant as well as before. There only seems to be a 5-10 degree delta between the 197 and the 187 deg t-stats, according to the gauge and the gauge button reading. Everything is working to plan I guess.
Mick
Old Mar 7, 2007 | 09:13 PM
vette1111's Avatar
vette1111
I have a 160 deg. in mine, and it runs 180 most of the time. Rarely does it ever get to 200 fans at 212 &225 I think?.
Old Mar 7, 2007 | 09:16 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I have a 160, fan kicks at 190, and never gets above 190 (in normal driving)...
Car runs great with it...
Old Mar 7, 2007 | 10:59 PM
Mach2's Avatar
Mach2
I meant no negativity in regards to the 160 deg t-stat and those folks that us it. I just feel that the newer engines like this LS1, with reverse cooling, small combustion chambers, aluminum heads/block are meant to run hotter than the older style engines. That is the reason I went with a 187 deg t-stat. I'm going to use a Hypertech III to change the fan on/off temp settings from stock @ fan 1 on/off: 227/218 and fan 2 on/off: 235/228 to fan 1 on/off: 209/200 and fan 2 on/off: 219/210.
I may see how the Hypertech III does with a tune up.
Mick
Old Mar 8, 2007 | 11:51 AM
jovette's Avatar
jovette
Mick
Mick, check your information, the LS1 does not have reverse cooling like the LTI did. No need for reverse cooling on LS1 since it's an entirely new engine design without the cooling limitations of the old chev. small block.
Old Mar 8, 2007 | 12:22 PM
hotwheels57's Avatar
hotwheels57
The thermostat only controls the initial temperature at which the coolant will be allowed to circulate through the system. Once it begins circulating, the thermostat has no bearing on the temperature of the coolant until it cools and the thermostat closes. The coolant temperature will be whatever the system allows it to be. That's dependent on the radiator, fan(s), air intake, car moving or stationery, etc.
Old Mar 8, 2007 | 12:27 PM
Mach2's Avatar
Mach2
Thanks for the correct info jovette and hotwheels57. Like some of us, I think I know more than I do.
Mick
Old Mar 8, 2007 | 12:30 PM
hotwheels57
I come from carburetor hot rods. It was a common misunderstanding there (which I made frequently in my learning curve).
Old Mar 8, 2007 | 12:52 PM
Mach2's Avatar
Mach2
Funny you should say that hotwheels57. I got rid of a 32 Ford Highboy Roadster with a crate 350/350 trans, 8" Ford rear, glass body and tons of fun. Just got tired of the old school Hot Rods that I'd had previous to this C5. Holley carb leaking, blowing power valves, always wiping a leak. Loved it though.....
I'm lovin this new age Hot Rod, especially the 6 speed.
Mick
Old Mar 8, 2007 | 01:02 PM
hotwheels57
That's a nice highboy! I was into tri five Chevy 150/210 sedans, but got tired of the car shows. My Z16 satisfied a dream since high school.
Old Mar 8, 2007 | 01:08 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
same here.
Old Mar 8, 2007 | 01:15 PM
rustyguns's Avatar
rustyguns
i changed over to water wetter and man i run cooler now
Old Mar 8, 2007 | 01:21 PM
hotwheels57
I use WATER WETTER as well. From what I know, it's designed to make water more slippery (if that makes sense). There's a word for it and a long technical explanation, but "slippery" is so much easier to remember.
Old Mar 8, 2007 | 02:31 PM
Mach2's Avatar
Mach2
When I had this coolant system work done I thought about adding Water Wetter too. Read a few threads about it on this Forum and the concensus seemed to be the Water Wetter works good with water, but doesn't do any good with the coolant used in the C5 system, so I decided against adding it. Read where if you change the coolant every 20k miles, the system stays lubricated from the coolant.
Like I said earlier, I think I'm smarter than I really am so maybe I should have added the Water Wetter too.
Mick
Old Mar 8, 2007 | 02:48 PM
hotwheels57
I also read pros and cons about using WATER WETTER with water only or with coolant. You might check the REDLINE website for the manufacturers suggestions on that.
Both coolant and WATER WETTER have abilities to lubricate the water pump seals, but WATER WETTER has the additional ability to act as a surfactant (that's the fancy word meaning "slippery").
I've always run WATER WETTER with the orange extended life coolant (either DEXCOOL or newer versions from PRESTONE and others), w/o the pellets that caused so much grief in earlier LT1 motors.
I don't know if it's harmful, wasteful or hype, but I figure for all the money I've saved by not changing my oil every 3,000 miles...
Old Mar 8, 2007 | 03:13 PM
Mach2's Avatar
Mach2
I'll check Redline's website.
This brings up a question. If I were to add the Water Wetter, do I add it to the plastic coolant tank? How will the Water Wetter get circulated throughout the coolant system adding it there, or does the coolant in this tank circulate throughout the engine?
Just got off the phone with a Tech guy at Redline. First thing I found out was here in Central Calif you really don't need 50-50 Dexcool to water, I could go to 15-85 Dexcool to water for a more effecient cooling system good to -18 deg. Water Wetter is compatible with Dexcool, so again...........shows what I know (or don't know). He also says that adding the Water Wetter to the expansion tank will get it into the cooling system after about 4-5 heat-cool cycles.
Off to add some Water Wetter, L8TR.
Mick
Old Mar 8, 2007 | 04:03 PM
hotwheels57
...there you go...the expansion tank is the only place you can add the WATER WETTER unless you remove the top hose. The tank is where I add mine. I found SUMMIT RACING to have it for a good price if you can't find it elsewhere.
To Initial impression with 187 deg t-stat
Old Mar 8, 2007 | 05:30 PM
rustyguns's Avatar
rustyguns
Default oh yeah
with the added water and less anti freeze and the water wetter your gonna be happy!
cool man!
also............
you might want to blow out the exterior of your radiater, hi pressure water or air. the fins get clogged with road dust & dirt, the fog helps make a mud in there
so the increased air flow through your radiator will help a lot too!
and.......... you could get a higher flowing fan for the radiator also
seena few guys do that here on the forum and were pleasantly suprised
Old Mar 8, 2007 | 06:14 PM
Mach2's Avatar
Mach2
Thanks folks, appreciate your help. Water Wetter is going in tomorrow and then...............well, might as well take it for a little scoot, huh?
Cleaned out the front of the radiator at the dealer when the coolant system was flushed.
Let's Rock and Roll............
Mick
Old Mar 10, 2007 | 09:51 AM
nitecruizer's Avatar
nitecruizer
Mick
I love my vette and would never give it up but, my oh my I would like to park that highboy right next to my black vette, then try to figure out which one to drive. Neat car!!!
Cruizer
