[Z06] DOT 3 or 4
Old Mar 8, 2007 | 06:51 AM
thundavett's Avatar
thundavett
Default DOT 3 or 4
Looking for some advice and hoping some of you can give me some input. I was wondering if putting DOT 4 brake fluid into my Z06's brake system when its had DOT 3 the whole time and it clearly states on the servicing cap to put DOT 3 into it.
I've got a few bottles of unopened DOT 4 from my other car I sold and I was going to drain and flush the brake system with DOT 4 when I'm due to change my brake pads and or rotors.
Old Mar 8, 2007 | 09:21 AM
vms4evr's Avatar
vms4evr
DOT 3 or 4 is just fine. DOT 3 is the minimum. I used Castrol Synthetic until I started tracking my car. Now I run Motul RBF600 in it year round. No problems.
While you're doing the flush. Do the clutch reservoir drain,clean,fill. Whatever you have that you are using for the brake fluid use for the clutch.
Old Mar 8, 2007 | 10:02 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
^Yep. When I switched over to Dot 4 for the first time. I did a tech II bleed and got all of the old fluid out. Have used the dot 4 for brakes and clutch as well. Don
Old Mar 8, 2007 | 10:31 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
It does not matter which you use. They both will work. It is just the Dot 4 has a higher boiling point.
Old Mar 8, 2007 | 02:47 PM
FasterIsBetter's Avatar
FasterIsBetter
DOT 3 or 4 is good. If you track the car, you should use one of the racing fluids with a very high dry and wet boiling point. For normal street driving, any good 3 or 4 works fine.
But be very careful NOT to us DOT 5, which is silicone based fluid. DOT 5 does NOT mix with DOT 3/4 fluids and you can end up with major problems if you put in DOT 5 without completely flushing old DOT 3/4 fluid and completely cleaning the system.
Old Mar 8, 2007 | 06:13 PM
thundavett's Avatar
thundavett
All, thanks for the input. I haven't looked into it but is the cluch servicing a tough job, do you need a pump to do the job or does it just drain out? Is it a two man job? I've always had automatics until I bought my Z06. Thanks
Old Mar 8, 2007 | 06:49 PM
lbarnard's Avatar
lbarnard
ATF Blue!
Old Mar 8, 2007 | 07:00 PM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
Brake Fluid 101
http://www.shotimes.com/SHO3brakefluid.html
I run Castrol SRF, yeh it's pricey-but I get away with doing a Tech II once a yr, run 8 DE's a season and no brake fade, love it.
Old Mar 8, 2007 | 09:32 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i just flushed the system about a month ago using DOT 4.
Old Mar 8, 2007 | 10:15 PM
vms4evr's Avatar
vms4evr
Easy job. There is a small reservoir next to the brake master. That's the clutch reservoir. Get syringe, turkey baster, whatever. Suck the stuff out completely. Wipe the reservoir nice and clean. Fill with fresh brake fluid. Done.
You can search for this and you'll find a topic Ranger posted on this.
Old Mar 8, 2007 | 10:18 PM
vms4evr's Avatar
vms4evr
I could have swore I read somewhere that SRF is hard on magnesium. The Z06 has magnesium in the brake system. I do about 8 track events a year also and a small dose of AX. I'd love to do a full flush once a year and be done with it... I've got DRM ducts and will have spindle ducts soon. I bleed off the calipers after every event. Just an ounce or so on each wheel as I swap tires/pads around.
To DOT 3 or 4
