Code P0440 H C?
Old Mar 10, 2007 | 02:22 PM
magredvet2's Avatar
magredvet2
Cruising
Default Code P0440 H C?
I had a clutch installed last monday, and since then, I have had the fuel gauge dive to zero once, and now I have the check engine light on with a P0440 (evap emissions system) code.
Firstly what do I check to fix this recurring code, and secondly, is there anything common to these two problems, that would have something to do with the clutch install, for example, a ground connection somewhere, that has to be disconnected to remove the rear cradle.
Any advice on how to troubleshoot this problem is appreciated
Thanks in advance
Old Mar 12, 2007 | 06:45 AM
magredvet2's Avatar
magredvet2
Cruising
Anyone have any clue about the P0440 ?
Old Mar 12, 2007 | 07:53 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
The codes sometimes changes year to year and I do not see that code in my list of 2004 vettes. However it seems like it might just be the gas cap which I have had problems with. Try removing it and replacing it. Clear the code and see it it come back.
Old Mar 12, 2007 | 08:50 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
9 times out of 10 your gas cap is not tight.
Peace
Chip
__________________
..................Click for
Old Mar 12, 2007 | 12:34 PM
magredvet2's Avatar
magredvet2
Cruising
I cleared it once, and it came back after two days, I'll clear it again, tighten the gas cap, and see if it comes back.
What's the next thing to look at, if it's not the cap ?
Just seems strange that I've had no codes thrown for 4 years, I get a clutch changed out, and it throws this code, oh well must just be coincidence
Thanks for the replies
Old Mar 12, 2007 | 01:20 PM
CCA Corvette Parts
If your gas cap is tight, first try a new gas cap.
Mine was shot, cleared up the codes.
If that does not work, you will have to take it in for an EVAP test, becuase you have a leak somewhere...
Peace
Chip
To Code P0440 H C?
