Spark Plug Change....hot or cold?
Old Mar 10, 2007 | 04:36 PM
HiLandR's Avatar
HiLandR
Default Spark Plug Change....hot or cold?
Which is easier to change the plugs, while your car is hot, or cold? I know a lot of people have trouble the first time, I think these are original plugs, the car has 40k on it. Thanks in advance for any help!
Old Mar 10, 2007 | 04:41 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Personally - I always preferred to do it cold, only because of not burning my delicate fingers. But I suppose with an all aluminum block, if it was hot it might be easier to break the plugs loose......I guess I'd still do it cold.
Midwest Vette's Avatar
Midwest Vette
I have heard that with alum. heads you want to change plugs with the engine cold.
Old Mar 10, 2007 | 05:13 PM
BlackZ06's Avatar
BlackZ06
You don't want cold air pouring into a hot cylinder through the plug port.
Old Mar 10, 2007 | 05:28 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Bro like I said over MSN, do it with the engine cold. Use that double swivel socket and long extension and start out with plug number 7. Pull the wires from the boots and not from the wires themselves. Take your time. If you run into any problems, give me a call and I will walk you through it
Good luck! I know you will get'er dun!
Old Mar 10, 2007 | 06:53 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Actually doing it cold has merits because of less chance of sticking in the threads. Meaning you won't pull them out with the plugs when you back them out...
Nouman is right on, OF course!! Ask him how many times he's changed plugs in his baby!! Err...maybe how many times Oak has changed them???
I have to wonder though Nouman... Doing # 7 first?? WOW... Poor Shannon, he will be cussing in no time but at least the rest is cake after you get past that one.
Also, Shannon, get some wires too!! Don't mess around with old wires... Yours are 6 years old!! They are hard to pull off, you tear or break one partially and it's now a problem... Get new wires and be done with it!!!
Old Mar 10, 2007 | 08:19 PM
HiLandR's Avatar
HiLandR
Got 7 done.
Another Q??? Is it best to pull the plug wire boot to get it off, or the aluminum shield?
How much are wires at a local store?
BTW, Nomy and Oak, answer your phones!
Old Mar 10, 2007 | 08:49 PM
HiLandR's Avatar
HiLandR
Update: After getting 7 off and replaced, I butchered #5 and the damn boot brke off in my hand! I guess you were right John, I'm off to the store!
Old Mar 10, 2007 | 09:04 PM
I too have always heard to change the plugs when the engine is cold on these cars. Going to find out soon since I want to change my plugs.
Old Mar 10, 2007 | 09:58 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
FSM says change'em COLD.
Old Mar 10, 2007 | 10:05 PM
FactoryRaceCar
Shannon sorry did not answer the phone earlier.
I thought about telling you about the new wires but I knew you were tight on the budget. Oak still has my old wires if you want to ****** them instead of buying the new ones.
But do as I told you over the phone with the wires that you are getting. No clarification required here I hope.
Call me anytime if you have any other questions!
Old Mar 10, 2007 | 10:38 PM
HiLandR's Avatar
HiLandR
Murphy's Law #99999xxxxxxxxxxxx:
If you think you can save your wires, and yoo post on CF that you will, the next wire yiou try to remove, you'll split like an atom!
that is all!
Old Mar 10, 2007 | 10:40 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
So warm? Not hot... not cold
Old Mar 10, 2007 | 10:45 PM
z06Bigbird's Avatar
z06Bigbird
Some experienced GM service managers have told me that when you install plugs in a hot vette engine, they are very likely to freeze in there after about 50 k miles.
Ed
Old Mar 10, 2007 | 11:36 PM
oaks99's Avatar
oaks99
sorry bro but i was at my in-laws we sold my father-in-laws cattle today , so we were out there for dinner .
oak
Old Mar 11, 2007 | 01:32 AM
HiLandR's Avatar
HiLandR
All done, hands are thrashed but the pesky ping is gone and I feel a bit more pull! Nouman was right as usual! :o
thanks to all that helped!
John, Nouman, Oak
Old Mar 11, 2007 | 01:33 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
oak
Hmm selling cattle... eating dinner.... Was that a FRESH steak you had for supper Oak??? Nah, I'm sure you'd age that baby for 21 days wouldn't ya? I would!!
Shannon, the wires degrade with time, temperature and such. (I'm sure you know this) It's hard to keep them in one piece when they are a few years old. It's also one of those things that until they get real bad, you really don't know how bad they are...
I hope you put die-electric grease on the new wires for a nice connection? Also, did you use anti-seize on the sparkplugs when you put them back in?
To Spark Plug Change....hot or cold?
Old Mar 11, 2007 | 01:36 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
John, Nouman, Oak
Once again, I did very little to aid in this endeavor...dang...
It is amazing at the difference in HP when going from an old worn out set of plugs to a new fresh set!! That hotter spark works wonders!!
Old Mar 11, 2007 | 09:30 AM
Frozenfire's Avatar
Frozenfire
I see you posted this yesterday and you're probably done, but I hope you put some anti-seize paste on the threads before you installed the new plugs. It'll save you some trouble the next time you do a change.
Old Mar 11, 2007 | 11:48 AM
oaks99's Avatar
oaks99
jon
we had chicken .
i guess i'm going to have to do mine , shannon would you like to do mine since you now are a pro at it .
