On My GMLink, under maintenance, it has a listing for things to be checked at least onece a month. These include things such as loose ore damaged parts, safety belts, wiper blades, greasing weather strips, and "Check the transaxle fluid level; add if needed." https://www.mygmlink.com/main/US/en/...ubaction=least
Is that correct? I am hoping this is a generic deal and they are refering to a FWD transaxle.
I've read in a couple of places that the best thing is to watch for leaks. One of the Corvette magazines did an article on this in a tech section. Checking the ATF in one of the A4 cars is not for the faint of heart. It involves getting under a running car, with a hot stainless steel set of pipes very near you, and removing a plug while hoping not to get an armload of hot fluid down your arm.
In my case, fostering a relationship with a good transmission shop is valuable. Because they do the maintenance on all my cars - my Vette, the Shelby, my wife's daily driver, my son's old Trans Am, and my old Trans Am - they've been really good about checking the fluid if I watch for a slow time. Takes them a couple of minutes on a hoist - would probably take me half a day at the emergency room to take care of the burns afterward.
Really, I've got the oil pans down for all the cars, and have a pretty good idea what's dripping out of them at any point. We could identify the power steering problem on my son's car, and I know the Shelby has a transmission pan gasket leak. Next time it's near the transmission shop, I'll pay them to check and change it. It just dries out from non-use.
One of those long catch pans, or some cardboard (my wife's Pontiac is still nearly new, so cardboard does fine there - same with the Corvette), is not a bad investment.
