Need help with tire sensor.
Old Mar 12, 2007 | 08:20 AM
Ghost Vette's Avatar
Ghost Vette
Default Need help with tire sensor.
Does any anyone know what type and number of battery you use for the tire sensor on a 97? Got one after tire change that won't come up. Thinking I might try a new battery for replacing.
Old Mar 12, 2007 | 09:29 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
There is no oem battery replacement. There is a thread on replacing the battery in the forum. It involves cutting the sensor open soldering a battery in and sealing up the sensor. I have not heard how dependable this method is. Check with the forum vendors on purchasing a new one.
Old Mar 12, 2007 | 10:03 AM
Personally I'd just get a new one. Cost is about $330 for a set of four, so about $82.50 each through GMPartsHouse.
Old Mar 12, 2007 | 10:28 AM
87SAM's Avatar
87SAM
From the how to pictorial I pickup on the forum, the battery is a common 3 volt Lithium CR2477N.
Old Mar 12, 2007 | 12:50 PM
Ghost Vette
I think you are right. This seems to be something that may be more trouble that it's worth. I would hate to go to this much work and find it didn't fix things.
I think a new one is in order.
To Need help with tire sensor.
