Stock C5 dyno sheet??
Old Mar 12, 2007 | 01:36 PM
brandtdavis's Avatar
brandtdavis
Default Stock C5 dyno sheet??
I've searched with no luck for a stock C5 dyno sheet. Horesepower and torque from apporx. 2500 - to redline for a 1997 MN6 if possible or other 345 HP car.
thanks,
Brandt
Old Mar 12, 2007 | 01:48 PM
DrWorm's Avatar
DrWorm
I have a 00 coupe and the only performance mods are a blackwing and 8mm plug wires. My dynojet numbers were 225rwhp / 234 torque.
Old Mar 12, 2007 | 01:53 PM
bbentley40's Avatar
bbentley40
Those numbers seem very low to me.. did you mean 325/334?? My stock Camaro SS pulled like 315 rwhp when I had it and it was stock at the time. Still havent put my Vette on the dyno.
rcknusa's Avatar
rcknusa
That sounds right to me. They screwed up my dyno but it certainly wasn't going to be any where near the 345hp with drive train loss.
Old Mar 12, 2007 | 01:55 PM
sigma6's Avatar
sigma6
225rwhp?! WTF? That's 33% loss? That can't be right
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
dyno numbers are very subjective. some read high, some read low.
fwiw, my car made 338rwhp on a mustang dyno but yet still ran 11.8's @ 115ish
Old Mar 12, 2007 | 01:58 PM
brandtdavis
thanks guys I'm looking for the full print out range of numbers so I can compare my numbers to a stock factory car. I'm searching google too.
Old Mar 12, 2007 | 02:05 PM
DrWorm's Avatar
DrWorm
HAHA yeah, 325/334! (oops)
Old Mar 12, 2007 | 02:50 PM
sigma6's Avatar
sigma6
Whoa. Good driver!
Old Mar 13, 2007 | 10:48 AM
brandtdavis
also looking for a stock C6 if possible. anybody??
Old Mar 13, 2007 | 12:25 PM
Square's Avatar
Square
Here is my 99' coupe 6 speed. The car was and still is bone stock including the air filter. This pull was done at approx. 10K miles.
Old Mar 13, 2007 | 12:33 PM
Corvette Don's Avatar
Corvette Don
You scared me with that one, I am going to have mine dynoed here in a bit...
Old Mar 13, 2007 | 12:35 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Come on now. He said "stock" There are zero stock C5's making those #'s Geesh.
Old Mar 13, 2007 | 04:27 PM
brandtdavis
Its ok to get off topic a bit.
Here is an example of what I'm looking for a 97 mn6. Or other slightly modded car (filter, cat backs, etc.) would be ok. I want to copy and paste them into excel. I can't exactly do that with a graph.
1998 C5 Corvette
Test Weight: 3850 lb
Tranny Type: M
TC Stall RPM: N/A
Axle Ratio: 3.42
Test Gear: 1.78
Tire Width: 275 mm
Tire Aspect: 40 %
Wheel Diameter: 18 inches
Drag Coeff: 0.32
Drivetrain Loss: 0
Air Temp: 75 F
Rel. Humidity: 44 %
Barometer: 30.06 In
Elevation: 800 Ft
Correction Fact: 1.022 SAE
RPM TQ HP
1800 267 93
1900 268 98
2000 270 103
2100 271 109
2200 273 114
2300 274 120
2400 275 126
2500 276 132
2600 277 137
2700 278 143
2800 281 150
2900 282 156
3000 283 161
3100 283 167
3200 283 172
3300 283 177
3400 284 184
3500 287 191
3600 291 199
3700 293 206
3800 293 212
3900 294 218
4000 295 224
4100 296 231
4200 295 236
4300 295 241
4400 294 246
4500 296 254
4600 295 258
4700 292 261
4800 288 263
4900 286 266
5000 289 275
5100 288 280
5200 285 282
5300 274 276
5400 265 273
5500 263 275
5600 259 276
5700 255 277
5800 247 272
5900 249 279
6000 248 283
6100 247 286
Maximums:
Torque: 296 lb/ft @ 4500 rpm
Horsepower: 286 hp @ 6100 rpm
thanks,
Brandt
Old Mar 13, 2007 | 04:53 PM
keanucosmo's Avatar
keanucosmo
Sure you can. You may have to do a little work instead of cut & paste, and may be off a couple of hp or tq at a particular rpm. For what it's worth the graph above is very close to my MN6 98 when it was stock.
I would think elevation at Va Beach is probably close to sea level.
All dyno runs I've seen are done in 4th gear which is 1.0
Weight & Drag coefficient have no impact on a dyno run.
Old Mar 13, 2007 | 05:07 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
1998 C5 Corvette
Tranny Type: M
TC Stall RPM: N/A
Axle Ratio: 3.42
Test Gear: 1.78
Tire Width: 275 mm
Tire Aspect: 40 %
Drag Coeff: 0.32
Drivetrain Loss: 0
Air Temp: 75 F
Rel. Humidity: 44 %
Barometer: 30.06 In
Elevation: 800 Ft
RPM TQ HP
1800 267 93
1900 268 98
2000 270 103
2100 271 109
2200 273 114
2300 274 120
2400 275 126
2500 276 132
2600 277 137
2700 278 143
2800 281 150
2900 282 156
3000 283 161
3100 283 167
3200 283 172
3300 283 177
3400 284 184
3500 287 191
3600 291 199
3700 293 206
3800 293 212
3900 294 218
4000 295 224
4100 296 231
4200 295 236
4300 295 241
4400 294 246
4500 296 254
4600 295 258
4700 292 261
4800 288 263
4900 286 266
5000 289 275
5100 288 280
5200 285 282
5300 274 276
5400 265 273
5500 263 275
5600 259 276
5700 255 277
5800 247 272
5900 249 279
6000 248 283
6100 247 286
Maximums:
thanks,
Brandt
Test weight of 3850!!!
Old Mar 13, 2007 | 05:20 PM
Corvette Don
I just dynoed mine and I only have a couple small mods
http://forums.corvetteforum.com/show....php?t=1648522
To Stock C5 dyno sheet??
Old Mar 13, 2007 | 05:42 PM
sigma6's Avatar
sigma6
Whoa wtf? You have THREE dead bodies in your trunk?
Old Mar 13, 2007 | 05:50 PM
brandtdavis
forget all that other stuff. It was just an example I said. I found it on a webiste. I just want RPMS, HP, and TQ in table format.
Old Mar 19, 2007 | 10:22 AM
brandtdavis
still looking
