Just got back from the Dyno...
Old Mar 14, 2007 | 05:05 PM
Corvette Don's Avatar
Corvette Don
Can you guys explain "sae" and "corrected numbers" I am not understanding that
Old Mar 14, 2007 | 05:07 PM
Corvette Don
Originally Posted by edcmat-l1
Yep. Exactly. Very nice for what it is.
PS would love to see a graph of the air/fuel
[IMG][/IMG]
Old Mar 14, 2007 | 05:21 PM
Corvette Don
All depends on what the A/F ratio is now. If its still real rich, like they come from GM, then you still have a chunk left. If its close to 12.8:1, theres not much to be gained from a tune.The correction factor is set to standard. It should be set to SAE. You'll loose about 7 or 8 HP on SAE, but it is a true-er number. Sorry......
It was only near 12.8 for a few 100 rpm so I think a tune would help. I am trying to understand what sae means over std but even if I am really at 325 whp thats still good eneough for me!! Ill have to fix my sig.
Old Mar 14, 2007 | 05:25 PM
edcmat-l1's Avatar
edcmat-l1
The CF up in the right hand corner. Stands for correction factor. There's 5 different ones, I believe. SAE is the most conservative. Stands for Society of Automotive Engineers.
Dont exactly know how they come up with the different CFs, but I do know that SAE is the most conservative. We use CF:SAE and set the smoothing on 5. MOST dynojet operators use SAE. Some use standard, just cause it shows a little better.
Your fuel looks a little leaner than a normal factory tune. They are usually dead on 11.3:1 or there abouts. Yours being a little over 12:1 is some of the power increase. The intake and supporting mods have thrown the MAF off a little bit. No biggy. A little more tweaking and get it close to 13:1 and you'll see some improvements. 5,8, maybe 10 hp
