98 CORRECT VOLTS WHEN RUNNING?? need help
Old Mar 15, 2007 | 01:45 PM
Keystone Joe's Avatar
Keystone Joe
Default 98 CORRECT VOLTS WHEN RUNNING?? need help
Quick Background: "new owner" of 98 Coupe (A4), Optima Red Top battery, if the car is not plugged to Battery tender charger it will be dead in 3 days. When fully charged, car starts and volts read 13.6/ 13.5. When driving it starts to DROP and after a 20 minute trip to work we are down to 13.1 to 13.2. Previously Had 3 3rd Gen T/A's and 1 98 T/A, and all GM cars for past 25 years, never seen a drop while driving unless maybe alternator going bad?? Can the good folks here give me a ballpark of "normal Volts" at start-up?, and does 13.1 seem logical while driving after a start at 13.6?? I will be going to the local AZ or Discount A for a test this weekend. Just new in the C5 world and wondering what is normal for the Volts readings out there. Appreciate any thoughts.. Thanks..,Joe
Old Mar 15, 2007 | 01:56 PM
87SAM's Avatar
87SAM
14.2 at start up, 13.7 - 13.9 when hot says mine.
Old Mar 15, 2007 | 02:13 PM
97vetteman's Avatar
97vetteman
Sounds a bit low, I have 14.1 volts on my drive to work. You could be right about your altenator being on the way out. Mine never drops below 14.1 while driving according to the DIC.
Old Mar 15, 2007 | 02:21 PM
blacksofttop's Avatar
blacksofttop
Mine's exactly the same.
Old Mar 15, 2007 | 09:35 PM
Keystone Joe
Default CORRECT VOLTS? Need Help
Thanks for the info, I definitely have a problem....
Old Mar 15, 2007 | 09:40 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 15, 2007 | 09:43 PM
sebringsilver97coupe's Avatar
mine "might" drop to 13.1 if im sitting ideling in drive at a stop light with lights on and music up very loud and the amp pulls enough juice for a strong bass hit on the sub but other than that im right with the others who have posted here.
Old Mar 16, 2007 | 07:10 AM
Sounds like low voltage to me. Might want to get the battery checked first and if OK, have other things checked.
Old Mar 16, 2007 | 07:51 AM
Scotty3's Avatar
Scotty3
I have a 98 Coupe (A4) with an Optima Red top battery too. Most of the time I am @ 14.1 VDC and the lowest I have ever seen was 13.6 VDC. Get your alternator checked out.
Old Mar 16, 2007 | 08:01 AM
Speckrig's Avatar
Speckrig
Old Mar 16, 2007 | 09:44 AM
Keystone Joe
Default CORRECT VOLTS?? Need Help
Gentlemen: Sincerely appreciate all of the great responses and info. Quick update. I had the Optima Red Top checked again at AZ, and they still tell me it is "good", but at start up all I have is 13.6 or 13.5 Volts on the DIC and the gauge shows the same. ,,, so tomorrow I will go back to another place to get the Alternator checked. One other item, The previous owner had put on new Gatorback belts to replace the stock and I am wondering if the tension might be incorrect? on the belt and therfore the alternator is Not getting the "full power action"??, could the new belts affect the "automatic tension adjuster?. Will keep you posted. Thanks again for all of the help from this great Forum... Joe
Old Mar 16, 2007 | 01:12 PM
CODE4LS1's Avatar
CODE4LS1
Interesting thread.....I also have a '98 Coupe and I have the same low voltage issues. After its warmed up mine reads 13.1-12.9. Maybe I should have my alternator checked as well
Old Mar 16, 2007 | 02:39 PM
terrystoy1's Avatar
terrystoy1
check to see if your volt meter is accurate. I found out that when mine reads 13.1 its actually should be 13.8. so don't panic just yet and have it checked to see what your ture voltage is. Your meter in the car could be off like mine.
Old Mar 16, 2007 | 03:10 PM
bighank's Avatar
bighank
Default DIC voltage is SCREWY
When mine starts sometimes it is anly about 10.7 volts. Climbs to 14.0 volts and then drops into the 13 volt range. Measure with a DVM at the battery if you want ACCURATE readings. Also my "NEW 900AH BATTERY" DIED in about 8 months. NEW is not equal to GOOD. New means NEW and thats all. When working as a service technician AGES AGO learned that very quickly. BIGHANK
Old Mar 16, 2007 | 03:51 PM
ALLEGRO's Avatar
ALLEGRO
To 98 CORRECT VOLTS WHEN RUNNING?? need help
