Question on GM Bra
Old Mar 16, 2007 | 09:46 AM
QuikZilver's Avatar
QuikZilver
Default Question on GM Bra
I am getting ready to purchase a bra for my freshly redone nose on my Z06. In reading some of the posts, I have found a lot of positive comments on the GM bra. I had one of the nylon bras, but that bra does not protect against rock chips and 4 of the 6 snaps broke off within 6 months of owning it, so I won't go back to that type. Speed Lingerie is nice, but not at the price. I know they fit great, but I just can't justify spending $ 570 on a bra. So, my question in regards to the GM Bra is the front license plate opening closed or open? I want the whole front nose protected on my Z. Thanks!
Old Mar 16, 2007 | 09:54 AM
travelingypsye's Avatar
travelingypsye
I have heard nothing but GOOD on the GM bra. You say you had a "nylon" bra? Is it the streatch material like the ones that c-5 creations sells? I was looking into getting one of those but if you had one & didn't like it ....well I might have to reconsider.
Old Mar 16, 2007 | 09:57 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
its closed, has a clear area so your plate is still visible.
Old Mar 16, 2007 | 09:59 AM
cadmanjm's Avatar
cadmanjm
Default GM Bra
It comes completely covering the front. It has a place to cutout for the license plate if you desire. I like mine for long trips.
Old Mar 16, 2007 | 10:03 AM
QuikZilver's Avatar
QuikZilver
Yes, I had one of those stretchy ones. It kept the bugs off the car, but you still got rock chips (nothing there to pad the impact of a rock). Here in South Florida, the rocks that come up off the road can be large. My nose looked like it had been hit by buckshot. Picked up the stretchy bra at first, still got a couple additional chips. Also, was in the rain once with the stretchy bra on and I guess the amount of rain that came down really water logged it and stretched it out even more, didn't fit as tightly. When the snaps broke after 6 months or so, I contacted them to see what could be done. I had bought it at Ecklers, so I wasn't sure if they would have me go back to Ecklers or if they would warranty. Never heard a word from them. Now that the nose of my Vette is perfect (had it refinished after being hit in the front), I want a bra that will protect it from rock chips. I brought it straight home from the shop on Wednesday and my wife won't let me drive it until I get a bra for it. She doesn't want the front chipped up, now that it is fixed. I just want to make sure the GM Bra also covers the front plate. If it does, I am ordering today.
Old Mar 16, 2007 | 10:04 AM
OsoBear's Avatar
OsoBear
Front license plate area is covered with clear vinyl opening, set into the black bra, that would kind of let the numbers be visible if front tag installed This covering is the same clear stuff that covers the driving lights and turn signals. Only actual openings in the bra are the two holes to let air into the brake cooler duct intakes. Got mine on Fleabay from a guy in Florida, (about $75 total) and had to get three snap posts locally as the ones included were too short. Directions included were lousy, but better ones are in tech section of forum.
QuikZilver's Avatar
QuikZilver
Great Thanks for the confirmation on this. Ordering it today!
Old Mar 16, 2007 | 10:06 AM
QuikZilver's Avatar
QuikZilver
I heard the Z06 Bra is open where the front vents are.
Old Mar 16, 2007 | 12:45 PM
Jet-Jock's Avatar
Jet-Jock
Here's a picture I took after installing my GM Bra:
I bought it for trips, specifically for the one I took from FL to BWG to STL and back. It worked excellent. No bugs or chips, no marring of the finish. The only thing I didn't like was the two sets of fasteners for the lower wheel wells were a little screwy and I replaced them with the other type in the kit (snap on a screw). The two sets they give you for those lower spots your suppose to remove the screw there, push the speed nut out of the way and the snap has a machined screw with a rubber piece on it. That is suppose to expand into the hole. It is much easier to use the self taping screw type and all you have to do is remove the existing body screw, leaving the speed nut in place, and screw in the snap screw. Bottom line a quick trip to the automotive store to get four of those fixed my issues with the kit.
Old Mar 16, 2007 | 12:51 PM
VetteBandit's Avatar
VetteBandit
Not that it matters now, but did you consider a clear 3M bra? This is meant to protect the paint from chips, cleans easily, is invisible and is cut to match the car. Plus you can get more or less of your car covered...just a suggestion.
Old Mar 16, 2007 | 12:55 PM
travelingypsye
Thank you for this info. I will now look elsewere for a bra. Probably a GM one.
Old Mar 16, 2007 | 12:59 PM
Jet-Jock's Avatar
Jet-Jock
See above post/picture...
The GM Bra has a very soft underside material to protect the finish and a tough exterior which creates additional padding from objects hitting it.
The nice thing about the GM Bra is you can leave your fasteners in place, pop the bra off and store it when your not using it. When your going some where or some trip, slip it back on.
Old Mar 16, 2007 | 01:49 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
I am getting ready to purchase a bra for my freshly redone nose on my Z06. In reading some of the posts, I have found a lot of positive comments on the GM bra. So, my question in regards to the GM Bra is the front license plate opening closed or open? I want the whole front nose protected on my Z. Thanks!
Got one recently. Fichtner's has them for $75 plus shipping. I believe they have you specify Z or non-Z but not sure why.
I would check with your painter but i have heard you need to be careful with fresh paint for about 6 months ?? Might pay to check it out. P.S. also got some black vinyl mirror masks from Ecklers for $30+
www.fichtnerchevrolet.com
Old Mar 16, 2007 | 02:52 PM
photoguy's Avatar
photoguy
I have the GM bra. I only use it on trips. Take it off when you are not traveling long distances so the paint can breathe.
Old Mar 16, 2007 | 04:55 PM
Bill Dearborn's Avatar
Bill Dearborn
The Z06 bra has openings for the air intake screens on the Z06. The bra has little tabs that slide in the slots above and below the screens. You would not want the Z06 bra on a standard C5 since there would be no place for the tabs except behind the bra. It is about the best bra on the market since it is tough and it is easy to put on and take off. Here is a picture of mine at about 80 mph.
It has been up to 145 many times (including a few seconds before this picture was snapped) with no problems.
Bill
Old Mar 16, 2007 | 05:02 PM
QuikZilver's Avatar
QuikZilver
Found one at West Coast Corvettes that has the logo stitched into the hood section. Think I will order theirs with mirror bras too. Can't put on for another 40 days, though. Paint has to finish curing.
Old Mar 16, 2007 | 05:04 PM
Jet-Jock's Avatar
Jet-Jock
Ah, it's Miller time.
To Question on GM Bra
Old Mar 16, 2007 | 07:22 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
The GM bra fits great and has an opening for the license plate with either the Z06 or regular C5 style bras. I used screw in marine snaps in the front wheel wells in place of the snaps that GM provided. The marine snaps are easier to install since they screw right in.
Old Mar 16, 2007 | 07:27 PM
C5XTASY's Avatar
C5XTASY
I have a brand-new, still-in-the-box, with all fasteners and instructions, GM Z06 bra, I'll sell for $70.00, shipped, anywhere in the continental U.S.
Ed
Old Mar 16, 2007 | 07:32 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Love the GM bra. I use it for trips only. I had it on once for a little over a week and noted a wear mark on the bottom where it wraps into the wheel well for snapping. I now put a strip of blue painters tape there prior to using the bra.
