replacing oil pressure sensor
Old Mar 16, 2007 | 06:20 PM
cbruer's Avatar
cbruer
Default replacing oil pressure sensor
Hey
Dealer says I have a bad oil sending unit which is located inside the intake. If I have to have this removed to replace the sending unit I figure it would be a good time to change to an LS6 intake or something else appropriate.
Any feedback on this?
I have a 98 C5 with Corsa exhaust, airbox and ignition.
Would this produce any noticeable gains?
thanks
Old Mar 16, 2007 | 06:44 PM
rws.1's Avatar
rws.1
happens to a number of us...
I am in the middle of the change out as we speak... about a 2 hour job...
read this thread
http://forums.corvetteforum.com/show....php?t=1588172
and this one
http://forums.corvetteforum.com/show...ressure+sensor
the move to an LS6 intake & block, 28# injectors 85 vs 74 mm MAF, improved cam profile (.500/0.500, 198/208 on 115.5LSA From: 0.472/0.479, 202/210 on 117)), and improved exhaust manifold only increased HP in '01 by 5 HP from previous years
Old Mar 16, 2007 | 06:54 PM
vetterlatethannever's Avatar
vetterlatethannever
Should be a do it yourself project. The LS6 won't gain you much now but short of doing a fast intake it will give you a good starting point for future mods. Mine is out too now by the way......
Old Mar 17, 2007 | 09:52 PM
berryj's Avatar
berryj
Bonus info:
http://forums.corvetteforum.com/show...ght=change+oil
To replacing oil pressure sensor
