Does this Look Legit?
Search eBay Motors Advanced Search
Back to list of items Listed in category: eBay Motors > Parts & Accessories > Car & Truck Parts > Turbos, Nitrous, Superchargers > Turbo Chargers & Parts
97-04 Chevy Corvette & Z06 Twin Turbo Top Mount Kit Item number: 250094185853
You are signed in Watch this item in My eBay
View larger picture
Current bid: US $1,875.50 Place Bid >
Reserve not met
price: US $3,500.00 Buy It Now >
immediate payment required
Make no payments for 3 months Apply
End time: Mar-20-07 17:08:01 PDT (1 day 22 hours)
Shipping costs: US $125.00
Standard Flat Rate Shipping Service
Service to United States
Ships to: United States
Item location: Auto Power Enterprise Offers Best Deals, United States
History: 6 bids
High bidder: User ID kept private
You can also:
Email to a friend
Listing and payment details: HideShow
Starting time: Mar-13-07 17:08:02 PDT
Starting bid: US $1.00
Duration: 7-day listing
Payment methods: PayPal
See details
Meet the seller
Seller: autopowerenterprise( 687)
Feedback: 99.4% Positive
Member: since Sep-18-05 in United States
Read feedback comments
Ask seller a question
Add to Favorite Sellers
View seller's other items
Contact the seller instantly
Buy safely
1. Check the seller's reputation
Score: 687 | 99.4% Positive
2. Check how you're protected
This item is covered up to $2,000 See eligibility
Description
Item Specifics - Item Conditon
Condition: New
This is the most complete twin turbo kit available for the C5 Corvettes, including the Z06 models. This kit will fit both automatic and manual Corvettes. It is brand new and comes retail sealed.
Two T61 T4 Turbochargers (Rated 600 crank HP Each)
Our turbochargers are both T4 flanged and feature 3" V-band exhaust outlets on the turbine side. They will bolt right up to the manifolds and connect to the twin downpipes using the supplied v-band clamps in the kit. These turbos are perfect for the 5.7L Motor, and make full boost at a mere 3500 RPM! This is a dream setup for the street. On pump gas and 8-9 lbs of boost you can expect to put out about close to 600 rear wheel horsepower (see dyno sheet below) which equates to 705 crank HP! With a built motor and race gas you will easily see 750RWHP + which is 900 crank horsepower.
Two 38mm Billet Wastegates
Our twin wastegates come with all the supplied hardware to install them, including all screws, nuts, bolts, flanges, and gaskets. These wastegates can hold up to 25 lbs easily with a stiffer spring. The included spring will run about 6-7 psi depending on the weather. At this boost level you can expect to make roughly 520 to 540 horsepower to the rear wheels. We recommend only putting in a stiffer spring if you plan on running race gas and have the necessary supporting components to handle the increased boost. Note that this turbo kit recirculates the air from the wastegates into the downpipes.
Bar & Plate Sheet Metal Intercooler + Intercooler Piping + 50mm Blow off Valve
Our custom made intercooler is designed to perfectly fit the C5 Corvette. It measures 24" long x 3.5" thick x 6" tall and has two inlets, one on each side of the intercooler. We supply the two intercooler pipes needed to route the air from the turbo outlets into the intercooler inlets, which each measure 2" in diameter. The outlet is 3" in diameter and is located on the top of the intercooler and we include the proper intercooler pipe to connect the outlet directly to your intake manifold. (Refer to picture 4). Our intercooler also incorporates a flange on one corner where you can easily mount the included polished 50mm blow off valve. No welding is necessary! Our kit is ready to be bolted on.
Please note that installing the intercooler in your Corvette will require a slight leaning back of your stock radiator in order to fit. We include two radiator plates and all of the other four support pieces to slightly move back your radiator so that the intercooler will kit. Rest assured, our kit is completely bolt on, no corners are cut.
Tubular Drivers & Passenger Side Headers & Two 3/4" Twin Downpipes.
Our turbo setup is a top mounting, which means you will see all the turbos, wastegates, and hot parts everytime you pop the hood. Our turbo headers are made of 321 stainless steel and are 1 3/4" mandrel bent. All of our welds are TIG welded and will not come apart. All inlet tubes are bead rolled and all exhaust connections are V-band connections. Our downpipes are a massive 3" diameter and will bolt right up to the included turbochargers using the supplied v-band clamps. Each header comes with a heat shield already put onto it to prevent excess heat from circulating around the engine bay (it is not visible in the photos below, but it is on the other side of the manifold which cannot be seen). The downpipes have wastegate flanges on them where the wastegates will connect to dump air into the exhaust. Our kits are street legal because the wastegates do NOT dump the air into the atmosphere, but rather into the exhaust. Each downpipe has two bungs pre-welded to fit your stock O2 sensors and also you can choose to run a wideband O2 sensor in order to monitor your Air/Fuel ratios. No check engine lights will be activated by installing this kit. We also include two turbo intake pipes, you will need to purchase air filters to mount on the end of each pipe. Our turbo kit will not require removal of air conditioning or any other factory parts.
Below is a complete parts list of what you will receive:
2 x T61 T4 Turbochargers (rated to 600 HP each)
2 x 38mm Billet Aluminum Wastegates with all fittings
2 x Turbo to Intercooler Pipes
1 x Intercooler to throttle body Intercooler Pipe
2 x Turbo Intake Pipes
1 x Custom Sheet metal Intercooler w/ twin inlets, single outlet and BOV flange pre-welded on
1 x Polished Billet Aluminum 50mm Blow Off Valve
1 x Mandrel Bent, Tig-welded and coated Tubular Exhaust Manifold - Driver Side - with heat shield pre-installed
1 x Mandrel Bent, Tig-welded and coated Tubular Exhaust Manifold - Passenger Side - with heat shield pre-installed
2 x Mandrel Bent, Tig-Welded and coated 3" Downpipes w/ O2 bungs - pre-welded
1 - Radiator Leaning Back Kit
Stainless Steel V-band Clamps
In order to fully install this kit, you will need to purchase silicone couplers, t-bolt clamps, and turbo oil feed and drain lines for the turbos. We also recommend upgrading your stock fuel injectors to 42 lb injectors in order to meet fuel demands. Unfortunately we do not sell these items, but you can easily find them at other retailers.
1 - The complete Corvette Twin Turbo Kit
2
3
4 - Custom Intercooler Setup - Notice the twin inlets on each side. Each turbo flows air into the intercooler through the support piping. The outlet on the top of the intercooler feeds air directly into the intake manifold. Blow off valve mounts effortlessly onto the pre-welded flange on the corner of the intercooler.
5 - The T4 turbo flange on the manifold. Notice the wastegate flange on the manifold. The wastegate recirculates the air into the downpipe through the flange on the downpipe.
6 -Turbo Intake Pipe - Two of these are included in the kit. You will need to purchase air filters to mount on the other end of each pipe.
7 - 3" V-Band exhaust flange on the turbine side of the turbocharger
8 - Blow off valve mounts directly onto the intercooler
9 - Turbo Manifold, you can slightly see the heat shield on the other side of the manifold.
10 - Supplied V-Band Clamps
11 - Everything that is included in the kit
12 - Freshly installed kit
13 - A car with the kit dynos at 589rwhp at 9 lbs of boost. Notice the smooth linear power delivery, not an on/off switch.
Proven Strong SS321 Stainless Steel and Full Tungsten Inert Gas (TIG) Welding and Unmatched Workmanship in all hot parts.
All of our items are brand new in retail packaging. They are not refurbished or used.
The Stainless Steel used in the manifolds and the full TIG welding technique used to weld it will ensure that it will not rust. It will resist pitting, cracking and fracture.
DO NOT BID ON THIS AUCTION IF YOU DO NOT AGREE WITH ANY OF THE FOLLOWING TERMS AND CONDITIONS, OR SHIPPING/HANDLING FEES
An invoice will be sent out to the winner within 24 hours of the sale. Item is to be paid for within 5 days of the invoice.
All sales are final; we give no refunds and accept no returns. We only offer an exchange if you have received an incorrect item.
The item is under warranty only against manufacturing defect for 30 days from the day of shipment. This warranty is rendered null and void if the item is damaged due to improper installation; it is misused, repaired, damaged or altered in anyway.
Non paying bidders will receive a negative feedback and an unpaid item strike.
We will ship via FedEx.
There is no pickup of items.
We offer neither installation instructions nor technical advice.
We cannot change or substitute any part of the kit. It is sold as-is. Please do not ask for us to change anything.
We Accept PayPal. We Also Accept Money Orders, And Cashier's Checks.
PayPal
We only accept your payment if you have a confirmed address with PayPal as we will only ship to that
confirmed address. Payments made with an address other than the billing address
will be refunded. We will only ship to the confirmed billing address on file with PayPal.
Money order or Cashier's check
Please Check Out On eBay First Before Sending Payment
With your payment, please include the following:
Your name, your address, your eBay ID, your phone number, your e-mail address, the eBay item number and item name
For The Continental U.S. addresses
Fast FedEx Ground Shipping
Flat Rate of $125.00, this includes insurance on the package. Adult signature will be required at the time of delivery.
Alaska, Hawaii, U.S. Territories, APO/FPO, PO Box shipping rates:
Alaska costs $450.00 for shipping & handling
Puerto Rico costs $375.00 for shipping & handling
PO Boxes & APO/FPO addresses cost $375.00 for shipping & handling
Hawaii costs $525.00 for shipping & handling
Feel free to use the "Ask Seller a Question" feature to ask us questions
00521
The power of protection from AOL and eBay. Learn more
Shipping and handlingShips to
United States
Country: Show all available
Shipping and Handling To Service
US $125.00 United States Standard Flat Rate Shipping Service
Country: Show all availableUnited States
Shipping insurance
Included (in the shipping and handling cost)
Return policyReturn policy not specified.
Read item description for any reference to return policy.
Payment details
Payment method
Seller's payment instructions
We prefer to receive your payment through Paypal. Please pay right after you check out so that we can ship your item immediately. When sending money order or chashier's check, Please include with your Payment Your Name, Your Shipping Address, Your eBay ID, Your Phone number, Your Email Address, Item Number and Description.
HelpTake action on this item
Item title: 97-04 Chevy Corvette & Z06 Twin Turbo Top Mount Kit
Place a bid
Your maximum bid: US $
(Enter US $1,900.50 or more)
Place Bid >
You will confirm in the next step.
Buy It Now
price: US $3,500.00-
Buy It Now >
(immediate payment required)
The seller requires you to make immediate payment to claim this item. You will be asked to do so with PayPal on the next page. Learn more.
eBay automatically bids on your behalf up to your maximum bid.
Learn about bidding.
Purchase this item now without bidding.
Learn about Buy It Now.
You can also
This is a private listing. Your identity will not be disclosed to anyone except for the seller.
Other options
Back to list of items | Report this item | Printer Version | Sell one like this
Seller assumes all responsibility for listing this item.
About eBay | Announcements | Security Center | Buyer Services & Protection | Policies | Site Map | Help
Copyright © 1995-2007 eBay Inc. All Rights Reserved. Designated trademarks and brands are the property of their respective owners. Use of this Web site constitutes acceptance of the eBay User Agreement and Privacy Policy.
They used their picture of "their kit" from a forum members setup without his permission.
and this quote in their auction should be enough to sway you from purchasing...
"We offer neither installation instructions nor technical advice.
We cannot change or substitute any part of the kit. It is sold as-is. Please do not ask for us to change anything."
There was something about the red c-5 being a forum members car & no permission was given to use it.
Run, run away!
What happened to?:
"this is our product, we believe in it, we want to be in business tomorrow and we will back our product up".
Plenty of good vendors on this site who will tell you that.
