[Z06] 405 check engine light !!!
Old Oct 12, 2001 | 01:02 AM
cvdg's Avatar
cvdg
Default 405 check engine light !!!
Wandering if anyone out there has had the engine check light come on on a 405 with a couple of mods. FYI, I have installed Halltech's T1 package, skip shif eliminator and the Bassani x-pipe. When floring the car from 1st gear up too like 4th the light will come on right about 3rd gear (shifts being done right before redline). It starts blinking and when I slow down it suddenly dissapears. What could this be? Could this be related to the x-pipe or the T-1 package? Thanks.
cvdg :confused:
Old Oct 12, 2001 | 01:15 AM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Default Re: 405 check engine light !!! (cvdg)
cvdg,
Do a search on codes and how to retrieve fault codes. I think the first step here will be to determine what kind of code you are pulling!
Old Oct 12, 2001 | 03:07 PM
vetteturbo's Avatar
vetteturbo
I put the Halltec T1 On my on last night....Check engine light came on and stayed on......I reset the codes,,,a pcm problem,, and drove the car about 50 miles..Not coming on now..Dave
To 405 check engine light !!!
