Code P1571 ASR
It is the ASR Desired Torque
Look at this post it explains it all for you! You need not worry it's not a bad one, Here it is: http://forums.corvetteforum.com/show...Desired+Torque
Let us know what you find out!
Thanks,Matt
History DTC P1571 Stored and Will Not Clear #PI00219 - (Jul 2, 2002)
History DTC P1571 Stored and Will Not Clear.
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Vehicle may have a DTC P1571 [ASR (Automatic Slip Regulation) Desired Torque Circuit] stored in history that cannot be cleared. DTC C1277 (Requested Torque Signal CKT Malfunction) is NOT present and there is No Service Vehicle Soon lamp or powertrain related lamps on.
Recommendation/Instructions:
This is a normal condition. All 1997 YBs will have a DTC P1571 stored as history in the PCM that cannot be cleared.
If P1571 is current, follow the trouble table in SI Document Number 101551. It should be noted that the schematic in this document incorrectly lists a ckt 449 dk blu/wht and calls it Real Time Dampening. This ckt is not present and should be ignored for both 97 and 98 (Document Number 203769) model year SI. A Service Information Update has been submitted.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
If the code is current I can send you the above referenced diagnostic info along with schematics.
Bill
More than likely you will be able to fix it yourself and save the money from having to take it to the dealer
Now you can spend it on some mods instead! Like a VARARAM or something! If you do go to www.thelapd.com it's only $305.00 shipped
this month only! It's where I got mine and man what a flippin difference
Thanks,Matt
