Instructions for replacing headlight bulbs
Old Mar 19, 2007 | 07:10 PM
sjn25600's Avatar
sjn25600
Default Instructions for replacing headlight bulbs
I have searched the forum and can not find info on this so I am sorry if it is out there.
I am one of the people that always breaks something when I try these kind of things and I would hate to hurt my baby.
So if anyone has detailed instructions (maybe even pictures) on how to replace the headlight bulbs, I would really appreciate it.
Old Mar 19, 2007 | 08:39 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
The owners manual has instructions with pictures.
Old Mar 19, 2007 | 09:11 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
St. Jude Donor '05-'06
I am going to be nice and here are the instructions:
1. The headlamp doors need to be halfway open. Turn
the headlamps on, then quickly back to the parking
lamps setting. You may have to do this a few times
to get the half-open position.
You can also open the headlamp doors manually by
turning the adjuster counterclockwise.
2. Remove the screws using a screwdriver on each side
of the headlamp bezel.
3. Open the hood.
4. To remove the bezel, pull the sides slightly outward
and tilt the bezel forward. Pull the clip centered
above the lens outward. Be careful not to scratch
the paint.
5. Reach behind the lamp and turn the bulb
counterclockwise to remove it. Don’t touch the
halogen bulbs. The inner bulb is the high beam and
the outer bulb is the low beam.
6. Disconnect the desired bulb from the wiring harness.
7. Reverse the steps listed previously with a new bulb.
To Instructions for replacing headlight bulbs
