Passing an emissions
Old Mar 20, 2007 | 03:58 PM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
Default Passing an emissions
Looking at a c5 with basic bolt ons and a borla cat back system the owner is not sure about an emissions as he does not need it where he lives but I would need to in order to import to canada is there any reason to think the car may not pass if no cam or header work has been done?
Thanks any input would help.
Old Mar 20, 2007 | 04:01 PM
HummelS's Avatar
HummelS
Don't know about Canada - in California, the cat-back exhaust wouldn't be a problem, but an open-element air filter (like a Blackwing) can be problematic, depending on the inspector.
Old Mar 20, 2007 | 04:07 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
if it is only a cat back system, I can't see why emmisions would be a problem..
Old Mar 20, 2007 | 04:19 PM
RUNNINGMAN 1
Thanks for the replys I am a bit nervous only because due to location I would basically be buying and then flying nin to drive the car home and hope for the best when I have it inspected!
Old Mar 20, 2007 | 04:34 PM
RA91925's Avatar
RA91925
To be cautious, maybe you could ask the owner for a complete listing of modifications. Then contact your inspection station to see if they see any problems with the mods. If anything needs replaced, you would know in advance and can budget for it.
Where I live (Missouri), they hook up to the car's computer and determine if it passes. It took me two trips to the inspection center because the computer codes had all been reset (possibly by a low battery), and some of the things they check had not yet returned to "ready".
Old Mar 20, 2007 | 09:43 PM
topplezz's Avatar
topplezz
I'm in Canada aswell and I'm wondering if it would pass with a Vararam and B & B Bullets. I just received the Vararam and I'm debating on installing it, or maybe wait to until the emissions test is done. I have to do the emission test within a few months. Has anybody passed emissions with the Vararam on?
To Passing an emissions
