[Z06] Slight Hesitation during acceleration
Old Mar 21, 2007 | 02:42 AM
sspur's Avatar
sspur
Default Slight Hesitation during acceleration
My 03 Z06 has a slight hesitation when I accelerate in first gear. In took it to the dealer and they found nothing. It is starting to do it again when I really romp on it at about 5000 rpm. Th efull warranty is expired but I still have an extended warranty any ideas what the issue may be?
Steve
Old Mar 21, 2007 | 05:50 AM
BlackZ06's Avatar
BlackZ06
Steve
Traction control is probably stepping in and limiting engine torque. At 5000 RPM in a lower gear that would be common on these cars. Be aware, if you try this with traction control OFF that there is a chance the rear end will break loose and come around on you, especially if you also have Active Handling OFF.
Old Mar 21, 2007 | 09:34 AM
Black C5 Z06's Avatar
Black C5 Z06
Is your car stock? Also your fuel pump may be acting up since it's in the high RPM range. Hope you figure it out, bro!
Old Mar 29, 2007 | 11:42 AM
ArkansasZ06's Avatar
ArkansasZ06
Newbie question here , how do you disable the active handling and traction control seperately . Thanks !
Old Mar 29, 2007 | 12:24 PM
TheSandman's Avatar
TheSandman
Steve
Check to make sure none of your plugwires are loose
Old Mar 29, 2007 | 12:41 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
From the sticky FAQ at the top of the page
"Competitive Driving" Mode
As aluded to in the previous paragraph, Corvette's Active Handling system has a unique feature called "Competitive Mode", which allows the driver to disengage the car's traction control feature without giving up Active Handling's other benefits. Holding down the Active Handling button on the center console for five seconds enables Competitive Mode. This feature recognizes that at the hands of a highly skilled driver a bit of rear wheelspin may actually be desirable in autocross or other racing events. In previous years it was necessary to bring the vehicle to a full stop to enable Competitive Mode, but for 2001 this requirement has been eliminated.
Old Mar 29, 2007 | 01:19 PM
ArkansasZ06
Thank you ! I learn something new here everyday . Hope to get a better feel of the ins and outs of this message board soon , as to not be a pain to everyone .
Old Mar 29, 2007 | 01:49 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
No problem at all...
To Slight Hesitation during acceleration
