The tranny in my 02 is shot. Car is getting stuck in 4th gear and grinds when shifting into 4th. I'm in Orlando FL need some help on where to get a replacement?? Or should I have mine rebuilt? Everyone I've talked to around here doesn't seem to know anything except 4k which I think is ridiculous. I know you guys know it all so lead me in the right direction
The clutch is starting slip real bad too. I'm making around 420 rwhp right now and am thinking of supercharging so maybe this would be a good time to change the clutch. All help much appreciated !! THANKS AGAIN
I've had a spec 2, spec 3, and spec 5 and they are all awesome clutches...just depends on what you use the car for....if its a DD i woul d go with a spec 2 or 3.....if its a race car then the spec 5 is great...
also you can't go wrong with the textralia
Check out rpm transmission. They are a forum vendor. Probably also need to upgrade the clutch as well. Textralia seems to be one of the top picks right now. I think it is good to 700 rwhp.
