what do you want to pull ? , I'll be pulling a ski with mine this weekend, I'll get some pics. Your not going to hurt this car by pulling anything small. just watch your gauges and you will be fine. I pulled skies with my S2000 and it did better than some trucks
that shoud be fine you can find a hitch for about 115 on the web and put it on yourself, You will need to drill 2 holes and then you just bolt the rest on. I hooked my lights on the pass middle, and ran them out the tag.
Does the hitch affect the exahust. I have a borla exhaust...
Im not sure if it will work with aftermaket exhaust. do you have the website where you ordered the hitch from.
One exhaust it will not work with is the SLP Power-Flo because of the tip but it should work with others that have a gap... one guy down here has it with Borla Stingers
