Installing new rims
Old Mar 21, 2007 | 08:05 PM
BLUC5's Avatar
BLUC5
Default Installing new rims
I recently bought four pristine OEM chrome 2004 rims with nearly new tires and sensors from a CF member. I am going to put them on my '02 coupe this Friday. Will I need to do anything regarding the sensors? Will they sync up on their own?
Old Mar 21, 2007 | 08:19 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You will need to train the sensors so your car will recognize them. The procedure is available in the manual. It is step by step via your DIC. You will need a strong magnet to excite the sensors at each corner as the DIC tells you to.
Old Mar 21, 2007 | 10:21 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
This should help:
https://www.corvetteforum.com/techti...D=77&TopicID=1
Just use a strong magnet in place of the J41760 Tire Pressure Monitor (TPM) System Programming Tool.
Old Mar 21, 2007 | 10:26 PM
You will need to resync them with your car. If you have a decent magnet, the process is easy and takes only about 5 minutes.
Old Mar 21, 2007 | 10:37 PM
Bill Vett's Avatar
Bill Vett
Word of warning... If you have a very strong magnet put an undershirt around it. It will help to not chip or scratch the finish of the wheels. A friend used a speaker magnet and chipped the first rim.
Old Mar 23, 2007 | 02:50 PM
BLUC5's Avatar
BLUC5
Default Thanks
Thanks for the advice!! Getting ready for spring!! Hooray!
To Installing new rims
