[Z06] Lowering 2002 Z06
Old Oct 12, 2001 | 03:22 PM
Corpvette's Avatar
Corpvette
Default Lowering 2002 Z06
Have any of you lowered your 2002 Z06? If so, how much did you lower it, and would you recommend it?
Old Oct 12, 2001 | 03:37 PM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Default Re: Lowering 2002 Z06 (Corpvette)
Corpvette,
I've lowered two of my other C5's but not my new Z06, nor will I!!!
You really don't want to do this. You will scrap and rattle all over the place.
You have a classic, don't destroy it.
Old Oct 12, 2001 | 05:03 PM
Zee Freak's Avatar
Zee Freak
St. Jude Donor '03-'05-'06
I lowered mine with the factory adjustments (about 15mm I think). I know thats not much but for my puposes every little bit counts! :cheers:
Old Oct 12, 2001 | 09:13 PM
svcjmo's Avatar
svcjmo
Default Re: Lowering 2002 Z06 (ZEE FREAK)
Bull, Go ahead and Lowr it! Just lowered mine today and the shake at idle is gone! I took it down as far as the the stock adjustments allow front and rear and the really now is PLANTED. The adjust. lowered the front 1/2" and the rear 3/4".Now it doesn't look like it has 4 wheel drive.
Old Oct 12, 2001 | 09:22 PM
Multicar's Avatar
Multicar
2nd Gear
Had mine lowered as far as possible with the stock bolts which worked out to 3/4" front and rear. Then had it realigned which most(?) experts recommend. I can't tell any handling difference on the street, but it sure looks better to my eye.
Old Oct 12, 2001 | 10:12 PM
Zippy's Avatar
Zippy
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
Have been debating lowering mine...am still undecidede! :confused:
Zippy :chevy :chevy
Old Oct 12, 2001 | 10:36 PM
KMeloney's Avatar
KMeloney
Default Re: Lowering 2002 Z06 (EdwardETraylorIII)
Ack! I couldn't DISagree with this more! :eek: (Isn't America great?! :flag ) Yes, you WILL scrape on some inclines -- but what you'll be scraping is the rubbery/plastic flexible airdam under the nose, which is not a big deal. I have my '01 lowered @ 2", and I scrape from time to time. But since the airdam pieces are so flexible, I don't even see any wear.
Also, my car simply doesn't rattle. Does anyone's? These cars are tight! Simply no rattling of any kind before/after lowering.
Finally, lowering your car is TOTALLY REVERSIBLE (even if you cut the front bushings, you could replace the bushings -- but it sounds like you're just asking about using the stock bolts for lowering anyway). If you lowered your car, and you didn't like something about it, you can raise is right back up. You'll NOT be destroying your car.
I say go for it! The improvements in handling and looks will amaze you!
-Kirk
To Lowering 2002 Z06
