C5 LeMans Twin Projector Headlights?
Old Mar 22, 2007 | 06:29 PM
dmancheno's Avatar
dmancheno
Default C5 LeMans Twin Projector Headlights?
Has any one used these headlight from ProCarParts? I saw them on ebay. Does anyone know who else carries them? I've seen the SpectorGTR but over priced. Any feedback would be great.
Thx
Old Mar 22, 2007 | 06:41 PM
dwspas's Avatar
dwspas
Whats the price on ebay, I may be able do a little better.
Old Mar 22, 2007 | 06:56 PM
MNCorvette's Avatar
MNCorvette
Default mine are sitting in the garage.
since the site mentioned isn't a site sponser and the moderators are big into that i'll be able to be honest...
PROS the light they make is AWESOME much clearer and better aimed then factory.
comes with factory connection. literally plugs right in.
can't beat the price and the quality, other then the mentioned included moutns, is great.
CONS
mounting is the biggest con. after taking out the factory light and screwing on the four (each) black mounting tabs provided i saw that the tabs and the factory holes don't match. NOT a huge issue but will be a pain once i am ready to install the light.
second they only come in chrome and it has been hell trying to find someone to paint them black for me. that is the reason they are not installed yet.
Old Mar 22, 2007 | 07:22 PM
dmancheno's Avatar
dmancheno
I saw on there site coming this summer BLACK HOUSING...
Old Jun 10, 2007 | 03:51 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
They now have the BLACK housing and I am interested in hearing more reviews.
Nice write up MNCorvette!
Old Jun 11, 2007 | 01:53 AM
MNCorvette's Avatar
MNCorvette
Default my update
Well I found a painter to paint my lights. We went over a bunch of different designs with tape and decided on the one I used. He refused to let me have him decide. We did agree that we would not risk taking the lense off and destroying any special seal that might already exsist.
I am not sure after installing these lights that i would want the black housing. Those "vents" for lack of a better term on the top of the light actually lets light pass through them. Lucky for me I now have black paint on the clear plastic part that covers that area. the light isn't bright enough to effect your field of vision but is strange looking when looking at your car.
As noted in my earlier post I was right about the trouble installing the lights. There isn't much room for adjustment as far as getting them to sit flush with your fiberglass. They are cut perfect to fit in the opening it is just the mounts they give you do not match all factory mounting holes. It is very important you use all the mounting points in someway because without them your light will flicker as you drive down the road.
I am happy to report the low beam light is GREAT awesome crystal clear. Sadly the high beams need to somehow be adjusted. One points up 45 degrees and the other one sharply to the ground. I don't ever use the high beams so i haven't looked closer at adjusting them. There doese appear to be an easy adjustment screw for the low beams which i haven't had the desire or time to get at to adjust yet.
There is a quirk about these lights. Our flip up headlights appear to be on some short of time delay so when your turn on your headlights they don't turn on instantly giving your car time to flip them up first. Well without flipping there is still a delay between switching on and turning on. maybe there is a way to turn that off?
There is good news. The lights are sealed solid there has been zero water or vapor build up inside. At night when you are driving you cannot see your headlight at all due to the curve of the hood.
I am still torn on what i think of the lights. part of me wishes I would have listened to the old advice of "if it ain't broke don't fix it" I would also add especially if you don't use it that much.
please email me Interna119@aol.com for pictures.
Old Jun 11, 2007 | 03:35 AM
jdmvette's Avatar
jdmvette
Night Owl for life
post pics on the thread. if you don't know how send me a PM and i'll help you out.
Old Jun 11, 2007 | 03:59 AM
2klude's Avatar
2klude
Old Jun 11, 2007 | 05:40 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Wow, nice write up, it helps out a lot. DO you wish you would have spend a couple/few hundred more and got the other C5R headlight offered?
Some pix would be great too. Thanks again,
Micah
Old Jun 11, 2007 | 09:51 AM
MNCorvette's Avatar
MNCorvette
Default pictures as requested
All photo's taken with camera phone sorry.
First test fitting... shows the light passing through the top.
With just one installed notice all the chrome
Two different side views I also changed my front corners also made by the same company DEPO.
and finally the worst view of the headlights straight on from the front
As far as the other C5r style headlights out there I think i saved $300 buying this set and that is after paint. If i worked at a body shop or wanted to pay someone to do it for that 300 dollars or had access to metal bending cutting and drilling I think you would end up with a PERFECT finished product.
The other perk of this set up is the quad projectors. Some have, in my opinion, a strange mix of lenses or bulb set ups. I would really like a high rise hood to off set the humps of the lights. My lights came with four bulbs included now using H7 bulbs. It would be very easy to switch to an HID set up for around 150 dollars or so by just adding bulbs and ballast.
Old Jun 11, 2007 | 10:03 AM
DPG's Avatar
DPG
St. Jude Donor '06
do you have xenon lights installed in there? if you do, they will flicker on and get brighter as they warm up.
Old Jun 11, 2007 | 10:08 AM
MNCorvette's Avatar
MNCorvette
Default halogen
they are just regular bulbs right now... the light it white and bright enough that i haven't had the urge to go to HID's yet.
thanks everyone for the praise I just remember what it was like a year ago when i wanted to get these lights no one on the forum had any information on them.
Old Jun 11, 2007 | 11:19 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Did you initially buy the CHROME set and had the painting done? They have BLACK now, so I am wondering if the light passing through the top has something to do with that?
Micah
Old Jun 11, 2007 | 01:09 PM
MUKAK's Avatar
MUKAK
they look very good, i might have to buy me some!!!!
Old Jun 11, 2007 | 01:39 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
It is definitely in my very near future. Of course, I am getting the BLACK ones.
Old Jun 11, 2007 | 03:05 PM
MNCorvette's Avatar
MNCorvette
Default bought chrome
i bought chrome and had the lense painted black on the outside. If you go that route make sure the painter uses a black primer first so the light won't be able to shine through it. If they use another color you'll be able to see it from the inside out.
Old Jun 11, 2007 | 03:09 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Well, the same company you got yours from now offers BLACK and CHROME and I am getting the BLACK ones (when things finalize at home).
To C5 LeMans Twin Projector Headlights?
Old Jun 11, 2007 | 03:35 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I see you have to get the okay from the wife, I mean boss
Old Jun 11, 2007 | 03:38 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I am close!
Old Jun 20, 2007 | 11:23 PM
NemesisC5's Avatar
NemesisC5
