[Z06] question about simple mods????
Old Mar 22, 2007 | 08:17 PM
1slo6's Avatar
1slo6
Default question about simple mods????
do the TB coolant bypass and 160 thermo really work to pick up HP?
Old Mar 22, 2007 | 11:17 PM
jbauch357's Avatar
jbauch357
NO - you want a hot motor with cold air coming in. The colder thermostat will have little effect unless you have the fans set to come on at the lower temperature also, and air moves too quickly through the throttle body for a few degrees difference to have any effect on the air before it sees the combustion chamber. Save your money and wait until you can afford a good air intake, headers, or even a tune...
a post a week or so back outlined how a guy installed is TB coolant bypass wrong and pumped all the coolant into his PCV fresh-air intake and down to the crank case...
Old Mar 23, 2007 | 01:25 PM
1slo6's Avatar
1slo6
well i am about to get a tune i just saw that a lot of f-body cars do these mods. just curious didnt think much of a difference.
Old Mar 23, 2007 | 02:27 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
[QUOTE=a post a week or so back outlined how a guy installed is TB coolant bypass wrong and pumped all the coolant into his PCV fresh-air intake and down to the crank case...[/QUOTE]
DONT DONT DONT do it !!!
Search the threads for this post !! what a nightmare if not done properly !
Old Mar 23, 2007 | 03:48 PM
jbauch357's Avatar
jbauch357
yep - good you asked than. there are hundreds of worhless mods out there - unfortunately I have performed a few myself along the way hoping for gains that never materialized
To question about simple mods????
