Wheel wells?
Old Mar 22, 2007 | 08:45 PM
photoguy's Avatar
photoguy
Default Wheel wells?
Hey what do you guys clean your wheel wells with? I got some salt in there from the wonderful PA roads. Can I use armoural or something like it?
Old Mar 22, 2007 | 09:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
just a jet of water from my garden hose is all mine get.
Old Mar 22, 2007 | 09:07 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
pressure washer
Old Mar 22, 2007 | 09:12 PM
Oldvetter's Avatar
Oldvetter
ET, an old Forum poster and ex-GM Engineer, said "NO TOUCH" tire cleaner. It is in a spray can. ET had great looking wheels and brakes, and he kept his car CLEAN. Believe he used "NO TOUCH" once a year on his wheel wells.
Old Mar 22, 2007 | 09:13 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Take a rag and muck them out with warm water and soap....
Then once dry take your Ultra Shine Armor All and soak the inner fender !!
Will be dark and shiny !!!
Old Mar 22, 2007 | 09:22 PM
photoguy's Avatar
photoguy
Thanks all. I tried the pressure washer but it didn't take the salt off. Guess I can get in there with a brush and then use the tire spray and see what happens.
Old Mar 22, 2007 | 09:23 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Like Oldvetter said foaming tire cleaner will work (I just started using it as an engine bay detailer) In the past I detailed the underside of the wheel houses with Citrus Orange sprayed on quite heavy and not rinsed off but toweled off instead as it leaves a nice sheen. I just started using the tire cleaner on the engine and like the protective film it leaves but 'am watching to see if it attracts dirt.
Old Mar 22, 2007 | 10:16 PM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Thats what I use works real good.
Paul G.
Old Mar 22, 2007 | 10:22 PM
B-rent's Avatar
B-rent
Ive heard of people getting thier wheel wells rhion lined or another similar spray liner to help keep um dark and easy to clean.
Anyone tried this or have estimates of price?
Old Mar 22, 2007 | 10:30 PM
Oldvetter's Avatar
Oldvetter
Why would you spray "plastic" on "plastic wheelwells" ? Doesn't make sense to me. Just deal with the existing plastic wheelwells, besides those products are rough and would "trap" more dirt.
Old Mar 22, 2007 | 10:34 PM
Choreo's Avatar
Choreo
For the past 6+ years I have used Griot's Rubber Cleaner with a long-handled brush and rinsed. then followed with a light mist of their Undercarriage Spray http://www.griotsgarage.com/catalog.jsp?&SKU=11138 - this contains silicone and turns them dark black and only takes 45 seconds to do all four wheel wells. I would not recommend this product for any other use, but it works great on undercarriage and wheel wells
When I finally pulled my fender wells out last August to do my Dynamat install - they all looked brand new and I have driven the car everyday!
Old Mar 22, 2007 | 10:41 PM
rws.1's Avatar
rws.1
spray and soak for 5 minutes with a 1 part Simple Green, 3 parts water solution.
Then use the pressure washer to rinse clean.
Follow up with Aerospace 303 protectant...
Old Mar 22, 2007 | 10:43 PM
91LSMAN's Avatar
91LSMAN
I just clean them with a wheel cleaner and then follow up with a tire dressing.
Old Mar 23, 2007 | 08:24 AM
B-rent's Avatar
B-rent
I have heard of people doing it, must have been the other car's club im in. I guess corvette owners are smarter
Old Mar 23, 2007 | 08:35 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Clean with soap (found DAWN works great) and water.
Do not use Armor All- it will act as a magnet for dirt (stuff from the road, as well as break dust, will stick to it).
NO TOUCH works well - many here use it.
Another (old timers trick) is to LIGHTLY - I mean LIGHTLY, dampen a rag with WD40 and use this to 'blacken' the inner wheel wells.
You will need to wipe, and wipe again with WD40, and it will eventually put a shine, and remove discoloration, on the inner wheel wells.
Old Mar 23, 2007 | 09:21 AM
jrose7004's Avatar
jrose7004
I use Simple Green and a hose.
To Wheel wells?
