lowered then aligned?
Old Mar 23, 2007 | 05:15 PM
MiKeYs 2002 C5's Avatar
MiKeYs 2002 C5
Default lowered then aligned?
Hello, I just got my vette lowered the other day. I then took it in for an alignment. And the shop doing the alignment told me that they could only align it to the manufacturs specs. Is this how it should be aligned after being lowered. I would greatly appreciate the help guys. Thanks
Old Mar 23, 2007 | 07:42 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I would think that is what they should do. But maybe try a different shop.
Old Mar 23, 2007 | 07:53 PM
bcseitz's Avatar
bcseitz
They are just covering their butts. They don't want any legal issues if you get in a wreck.
If the car doesn't drive, steer or handle well then I would be very concerned and take it back.
I had a "recommended" Corvette allignment shop do a Z06 spec. allignment on mine. More caster, more neg. camber, ect., ect. You will have a bit faster tire wear if you do this. If the car is a daily driver, a stock C-5 allignment is just fine. You probably wouldn't want anything else.
Bob
Old Mar 23, 2007 | 07:55 PM
Jims2001's Avatar
Jims2001
That is how they aligned mine after lowering. It is just fine.
Old Mar 23, 2007 | 08:07 PM
50vette03's Avatar
50vette03
So if you get it lowered and stock bolts do you need to get it aligned? Or just leave it the way it is?
Old Mar 23, 2007 | 08:12 PM
02MillenniumVette's Avatar
02MillenniumVette
You need to get a four wheel alignment.
Old Mar 23, 2007 | 08:16 PM
Jims2001's Avatar
Jims2001
You should have it checked. Mine was off very little after lowering on stock bolts. Had about 6000 miles on car at the time. Watched and helped with the alignment. Was able to see the computer and compare the specs. Had more trouble getting it on the rack.
Old Mar 23, 2007 | 08:21 PM
MiKeYs 2002 C5
I had the biggest trouble today trying to find a shop that could get the Vette on the rack. I dropped it about an inch, and got new tires today. So, I defently wanted to get an alignment because I knew it was defently off after the lowering. And yes, it was off, but I had it aligned to man. specs and its all good now. Thanks guys
Old Mar 23, 2007 | 09:23 PM
rgtkst's Avatar
rgtkst
same here
Old Mar 24, 2007 | 10:07 AM
bcseitz's Avatar
bcseitz
If I remember correctly, mine wasn't too far off a Z06 spec allignment after lowering. I believe you gain a little more negative camber when the car is lowered. Z06's have more neg. camber (among other differences)(neg. camber = tops of the tires lean in, the bottoms stick out more)
So...it wasn't necessary for me to worry about rushing out right away to get a new allignment.
Hope that helps.
Bob
Old Mar 24, 2007 | 11:33 AM
jrose7004's Avatar
jrose7004
I'd let it settle for 200 miles or so then align it to ZO6 specs with no more than a -.25 camber.
Old Mar 24, 2007 | 03:20 PM
MiKeYs 2002 C5
I just got it aligned to manufacteur specs to a c5 coupe not a z06. Oh well, we will see how it all works out. Hopefully it doesn't mess up the new tires.
Old Mar 24, 2007 | 03:29 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To lowered then aligned?
